92 ls swap blowing white smoke and burning alot of gas
Old Oct 16, 2009 | 01:21 PM
JDMJohn413's Avatar
Default 92 ls swap blowing white smoke and burning alot of gas
I just finish swapping a 92 ls 1.8 motor in my eg8 the motor runs good starts good the only proproblem is that it blows a huge cloud of white smoke and its wasting a lot of gas I'm thinking headgasket anyone?
Old Oct 16, 2009 | 02:10 PM
tlarimer's Avatar
Default Re: 92 ls swap blowing white smoke and burning alot of gas
Sounds like a head gasket, is there oil in the radiator/or bubbles? Is there coolant in the oil? Does the exhaust smell sweet like burning coolant? Have you looked at the spark plugs? Do they have rust deposits on them?
Old Oct 16, 2009 | 02:36 PM
thecruzs2007@yahoo.com's Avatar
^^ headgasket..have you changed your cap and rotor? plugs? wires? can be different things on the fuel problem..
Old Oct 22, 2009 | 10:05 AM
JDMJohn413's Avatar
Iv replaced the headgasket,cap,rotor, n spark plugs, n motor is still blowing white smoke n its a big *** cloud. Could timing be a problem?
Old Oct 22, 2009 | 10:06 AM
raidacaipo's Avatar
3 words.. bad piston rings
Old Oct 22, 2009 | 10:11 AM
JDMJohn413's Avatar
You really think so bro? Damn man the thing that sucks is that I don't wanna pull that motor out after I just put it in. But if it really is high compression here I come.
Old Oct 22, 2009 | 10:27 AM
raidacaipo's Avatar
what color is the smoke exactly? light blue or just white?
Old Oct 22, 2009 | 10:47 AM
joemonster's Avatar
white = coolant
blue = oil
black = rich
When you get on it. you can smell it.. sweet smell = coolant
if it smells like burning, nasty lol.. gas or oil, they are pretty close in smell.
check ur bumper for black **** all above the exhaust, good way to tell. could also be carbon deposits, drive a few hundred miles, check your oil every few days, see if it drops. check everywhere for coolant and oil leaks.. could be a multitude of problems... I'm in the same boat as you.
Old Oct 22, 2009 | 10:56 AM
JDMJohn413's Avatar
I smell a sweet smell kinda n the smoke is light blue wen its idleing. Wen I changed the headgasket I cleaned the pistons but not the cumbustion chamber it did have a lot of carben on the cumbustion chamber. So what you guys think drive for a couple more miles or just change those rings. The best way I heard to clean the carben it to rev the motor 2 gran n spray some water but not a lot.
Old Oct 22, 2009 | 11:29 AM
raidacaipo's Avatar
light blue or any blue = bad piston rings
Old Oct 22, 2009 | 11:34 AM
Former User's Avatar
Oil burning in the cylinders might also be caused by leaking valve stem seals or a bad head gasket. Did you check whether the head and block were level before installing the new head gasket?
Old Oct 22, 2009 | 12:02 PM
JDMJohn413's Avatar
So what you guys think b16 piston for high compression or what why not I'm alread at it?
Old Oct 22, 2009 | 12:22 PM
Lambo123's Avatar
you should start with a compression and leak down test if you haven't done it already...
Old Oct 22, 2009 | 02:58 PM
JDMJohn413's Avatar
Could someone give me the psi spec for each cyl.
Old Oct 22, 2009 | 03:26 PM
xero_xero's Avatar
87 psi is the normal... just bought 3 ls motors and mine are fresh rebuilds, they hold 95 or higher and hold it for more than 10 minutes...
ford uses an oil in the cyilnder to expand the piston rings under high pressure, it would be something to explore.
Old Oct 22, 2009 | 05:29 PM
JDMJohn413's Avatar
By level you mean deck clarence?
Old Oct 22, 2009 | 07:30 PM
shogee's Avatar
new headgasket sorry dude sounds like you you have a cracked head or block
shogee's Avatar
like said above do a compression test and a leak down
buddy190
Feb 5, 2009 05:26 PM
mrboobz
Apr 25, 2006 09:02 AM
dominate9
Jan 8, 2004 07:01 AM
Broken Gearbox
Aug 8, 2003 09:00 AM
LSyellowREX
Aug 1, 2002 11:37 AM
