94 LS with GSR swap:: Jumpy Tach / NO Vtec
Old Oct 16, 2009 | 07:48 AM
LOVEthatDC2's Avatar
Default 94 LS with GSR swap:: Jumpy Tach / NO Vtec
whats up all ... well I just finished my gsr build and have no CEL's, car runs GREAT except that I have a jumpy tach when I'm driving (not so much when I'm parked although will jump if revved and kept around 3k rpm) and no v-tech (just took it to 5500 once and thats it since it's a new build I don't wanna mess with it) ...
do any of you know if the ls and gsr igniters are the same? I had to use an ls igniter (icm) since my gsr dizzy didn't come with any internals ...
I've been told it could be the speed sensor on my thread and am going to take the speed sensor off the tranny tomorrow and clean it like someone suggested.
Any other input would be great though, thanks!
build:: https://honda-tech.com/forums/showth...576253&page=11
Old Oct 16, 2009 | 09:12 AM
Default Re: 94 LS with GSR swap:: Jumpy Tach / NO Vtec
up
Old Nov 4, 2009 | 06:02 PM
l
Old Nov 4, 2009 | 10:34 PM
FRESHTEG's Avatar
does sound like the speed sensor
Old Nov 4, 2009 | 10:54 PM
karma28217's Avatar
As far as jumpy tach issues go, it could be the throttle positioning sensor on your throttle body or the speed sensor on the tranny. Most likely the speed sensor since the tach isn't jumpy during idle.
Old Nov 5, 2009 | 04:29 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Vss is the first thing to check!
Def why you have no Vtec..
Old Nov 5, 2009 | 05:48 AM
TonySemi's Avatar
I had same problem, speed sensor in my case
Old Nov 5, 2009 | 10:47 PM
cool, thanks guys ... gonna check that out tomorrow
Old Nov 6, 2009 | 04:50 AM
weavertime1's Avatar
Don't forget to actually look at the pins inthe VSS itself as sometimes they can get bent and not make a proper connection causing your VSS to malfunction. Good luck!
Old Nov 12, 2009 | 03:13 PM
ok so I took off the top part of the vss and cleaned it ... still nothing.
I'm afraid of taking off the whole thing from the tranny, will it just go back into place from the top? no need to take apart tranny? haha
Old Nov 15, 2009 | 10:24 PM
Old Nov 15, 2009 | 10:30 PM
lobudgetr's Avatar
Wait I'm a little lost, jumpy tach=VSS, I always thought jumpy tach had to do with ditributor, usually the igniter.
Old Nov 17, 2009 | 12:21 PM
so do I take the whole thing off from the tranny, will it just go back into place from the top? no need to take apart tranny?
Old Nov 19, 2009 | 10:02 PM
took the vss completely out and cleaned it (wasn't even dirty really) ... didn't change anything.
took your advice and took a look at the igniter and the blue wire was not as tight as it could have been so I crimped it with some pliers, put it back on and it works PERFECT now.
I figured it was something electrical too, thanks!
lwmmuas
Jun 11, 2013 12:24 PM
jlfrnce
May 9, 2007 11:05 AM
themorphious
Aug 22, 2005 01:29 PM
9hatchman4
Aug 10, 2004 09:02 PM
WAFFLES
Feb 20, 2002 04:19 PM
