H22/F23- which holes in the head shoul be blocked?
Old Oct 16, 2009 | 04:20 AM
pentaq's Avatar
Default H22/F23- which holes in the head shoul be blocked?
Could anyone show a picture of the holes in the H22 head which should be blocked while building H22/F23 hybrid, please?
Is it possible to tap them and plug with some stainless steel plugs sealed with hondabond? I really don't like the 'hondabond alone' idea there.
Thanks for your help in advance
Old Oct 16, 2009 | 05:13 AM
PirateMcFred's Avatar
Default Re: H22/F23- which holes in the head shoul be blocked?
I don't have a pic but it's the two drains closest to the timing belt side of the head. One on the intake side, one on the exhaust side.
Old Oct 19, 2009 | 01:49 AM
pentaq's Avatar
Just to confirm
Is that correct? Thank you
Old Oct 19, 2009 | 06:18 AM
hahaha. That head is familiar:
https://honda-tech.com/forums/showpo...2&postcount=73
But yes, those two drains need to be plugged.
Old Oct 19, 2009 | 07:23 AM
pentaq's Avatar
yeah you know, it had to be the very special head to make you interested enough to answer thanks again
Old Oct 19, 2009 | 11:51 AM
95greenlude's Avatar
I wonder if thats why I have an oil leak running down the front of the block.....
Hondabonded the rear, but left the front untouched
Old Oct 22, 2009 | 02:33 PM
pentaq's Avatar
OK, as I mentioned above I didn't like the idea of hondabonding these holes at all. So I took the head to the friend machinist and we made screw-in plugs.
The head is just to be cleaned and refreshed so don't worry about its condition. Of course the plugs will be sealed.
Old Oct 23, 2009 | 06:43 AM
I thought about doing that too. But I've had really good luck with Hondabond and close-fitting plugs in the past.
Nice job.
CA121
12
Mar 11, 2011 12:10 PM
Heads by Drew
Oct 21, 2008 04:12 PM
RACING INTEGRATION
Oct 23, 2005 07:59 PM
