View Poll Results: E85 SOHC or 91OCT F23VTAK?
E85 14:1 SOHC nonVTEC
47.25%
91 oct H22 head on 12:1 F23 block
52.75%
Voters: 91. You may not vote on this poll
@@@@ Help Pirate choose the next F23-based Winter build @@@@
Old Dec 31, 2008 | 12:04 PM
  #51
98vtec's Avatar
moderator emeritus
Default Re: @@@@ Help Pirate choose the next F23-based Winter build @@@@
cool it guys.
Old Jan 3, 2009 | 05:20 PM
  #52
alterdcreations's Avatar
pirate whats poppin with the build?
poor chris. alot of work when into his car and that sig is disrespectfull but to each is own.
Last edited by vinuneuro; Jan 11, 2009 at 08:25 PM. Reason: This is not the place to solicit sales.
Old Jan 12, 2009 | 08:53 AM
  #53
d112crzy's Avatar
So is building the Vtec hybrid your final choice?
I would like to have seen a sohc build done by you
Old Jan 12, 2009 | 10:58 AM
  #54
PirateMcFred's Avatar
It's pretty definitive that it will be an H22 head. It's already got the money in it and I never really got the chance to use it. If I started off with an F22 SOHC I'd have to spend the time/money into refurbishing it. I have a K24 that's getting all the nice parts (sorry the K24's more cost effective). No need to spruce up the POS Prelude. It just has to be practical and mildly entertaining for the daily commute/occasional track use.
Parts (including Type-S cams) cleaned up a bit:
Street ported H22 head.
Old DPR titanium retainers, stock H22A1 outers and DPR inner springs.
old Skunk2 gears.
Since I'm going to have the gearbox out I want to replace the synchros while it's easy to do so. I'll get some carbon synchros and see if I can swap in the M2B4 5th gear.
Old Jan 12, 2009 | 11:02 AM
  #55
vinuneuro's Avatar
Be careful with the Gearspeed syncro sets. People have encountered longevity problems with them.
Old Jan 12, 2009 | 01:50 PM
  #56
Nuts, any suggestions on a reliable alternative? I know SMSP sells synchro rebuild kits but I know know if his are any better than just going to NAPA...
Old Jan 14, 2009 | 04:53 AM
  #57
As usual the build is snowballing. I need new synchros, I need a new clutch, a light weight FW would be nice, I discovered a nasty dent in the secondaries on my header, the muffler/resonator packing is degrading and is not nearly as quiet as it once was, I need new brake pads, 2 new tires, looking at making/buying a balance shaft eliminator kit and I have not even bought the pistons yet.
owie:
I don't even remember hitting anything.
Old Jan 14, 2009 | 05:18 AM
  #58
vinuneuro's Avatar
SMSP only sells the syncros. Iirc, the hubs are often the problem as well. Which all gears are failing in yours..anything wrong with oem barring price?
Old Jan 14, 2009 | 05:45 AM
  #59
I have not had the gearbox out recently to look. After my Jan 5 half track day 5th gear has started to grind. I've never abused 5th gear. I think that the M2F4 has about 140k miles on it and I've not had it apart for the last 42K miles when I had the Quaife installed.
First through fourth are still pretty good. The track I use is short and tight 2nd-4th are the ones used the most.
It's just odd that 5th started grinding so suddenly. This weekend I think we'll try swapping in the spare M2B4 to prevent damage to the synchro sleeves/cogs themselves. OEM equipment is fine but the prices are pretty steep:
23521-p16-306 $300
23626-p16-316 $100
It also seems that the aftermarket after 17 years could engineer some improvements into the oem design which is a reason for trying something new but if it comes down to it I might have to spring for OEM if the steel parts are too messed up.
Old Jan 16, 2009 | 09:31 AM
  #60
GSR-EG-92's Avatar
Cant wait, I love the H-F series motors. I should toss the B18C out
Old Jan 21, 2009 | 12:40 PM
  #61
117's Avatar
117
Who? I have almost 3 seasons on mine without any problems.
Old Jan 21, 2009 | 06:33 PM
  #62
DaInFaMMuS1's Avatar
I don't want to blow $3k on nonVTEC for mediocre results.
-Pirate
to me, you answered your own question right there.
Old Jan 22, 2009 | 06:55 AM
  #63
I hope you're not thinking that just because it's not Hella Vtak y0! that it's bound for mediocre results. Besides it's going to be hella Vtak y0! anyway. It's been decided.
I think I'm looking at about $1800 for the build. Not exactly a small amount of scratch but not a bad price for quality parts.
Old Mar 17, 2009 | 08:25 PM
  #64
There's really no new updates here. I still want to build this but my motivation's stalled out at the moment. I've been looking at clutches and flywheels. I can't find a nice FW for a "reasonable" price so I'm thinking I'll grab a roughing endmill and a Hanita finisher and do something like this to my spare OEM FW at work:
Of course I'll have to get it balanced but I might as well do that to everything in the system, so it's not a big deal.
I've also grabbed a set of ARP head studs that will be used in the build.
I've also got an idea on how to plug the oil return holes in th head in a lightweight fashion.
And finally, I got some custom pistons on order too, ~4 weeks.
So many machine work projects so little time...
Old Mar 18, 2009 | 03:11 AM
  #65
LobeSex's Avatar
will doing this to the flywheel work??? ive never heard or seen anybody attempt something that out of the box to a flywheel
Old Mar 18, 2009 | 04:13 AM
  #66
Out of the box? It's just lightening the stock flywheel. All the important parts are still there. There are 8 bolt holes for the crank, a friction surface and mounting points and pins for the clutch and a ring gear for the starter. What's different than this ACT Chomoly Prolite or this OEM Honda K20A from a DC5 Type-R?
Old Mar 27, 2009 | 09:08 PM
  #67
Pistons are ~2 weeks out.
87mm
3 cc dome
22mm pin offset .030"
1.181 compression height
This is the H22 IM I'm going to use. It's had the EGR removed and the port welded as well as the runners ported a little:
Some nice RDX 410cc injectors are pending sale.
I've taken some measurements on the OEM flywheel. It weighs 18.4 pounds stock and it looks like I can get it down about 8-10 pounds depending on how much material I remove and where. I'm looking at 2 setups minimum and maybe up to four depending on how much I want to remove. I never noticed before but the ring gear's pressed onto the OD of the cast part. So it might be riding a fine line removing a lot of material from the OD without tweaking the ring gear's fit.
I've got work to do this weekend and I think I'll see what I can do to the FW then. I've got a "Want To Buy" post in the forum sticky here:
Linky
There have been a few offers on the lower timing gear but there's a few other items I'll need too. So PM me please if you have something.
So all in all it's coming along.
-P
Old Mar 27, 2009 | 09:11 PM
  #68
98vtec's Avatar
moderator emeritus
give me you damn address and ill send this **** out to you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ok sorry, im drunk.
but i do have the gear for you
Old Mar 27, 2009 | 10:44 PM
  #69
I understand that, but so do Acidcrakker, lude98SH, and 117. 117 has some of the other parts and I'm waiting to hear back from him on a final price quote so I can tell everyone that I don't need theirs. I'm trying to consolidate all the shipping as it's not cheap.
And I just found my old H23 oil cooler too. So nix that item from the list.
Oh! Blake, if it's within your power to rename the thread I'd appreciate it. Something about "'winter' build" would work for me.
Old Mar 27, 2009 | 11:28 PM
  #70
autoluder's Avatar
its spring now..ha
Old Mar 28, 2009 | 10:16 PM
  #71
I got a little done on the mill today. I got the first operation done on the clutch side.
Before
After
Dropped 2.3 pounds off so far and there's probably 5-6 pounds left on the back side.
Old Mar 29, 2009 | 04:23 AM
  #72
95greenlude's Avatar
wow....you have some amazing resources! I'm always impressed by what you cook up!
Old Mar 29, 2009 | 03:38 PM
  #73
Before:
After:
Final weight is 12 pounds. Ought to be good enough. It's not the lightest but I figure it's cast iron which is not nearly as strong a quality 4130 billet chromoly steel. I paid a lot of attention to removing as much material as I could from the OD where it's less structural and has the greatest influence on MoI. With a 180wtq engine it should rev pretty quick.
Old Mar 29, 2009 | 06:03 PM
  #74
great work man
Old Mar 30, 2009 | 06:23 AM
  #75
flyrod's Avatar
That's pretty neat. CNC mills are pretty useful--a little spare time and now that flywheel is 2/3 the weight and probably less than half the inertia.
