2000 Civic Si radio code
Old Aug 29, 2002 | 12:52 PM
NVMYSi's Avatar
Default 2000 Civic Si radio code
I unhooked neg battery terminal to install a VAFC and when I reconnected my radio won't work and Flashed CODE. I would have just used the owners manual but I bought the car used and it didn't come with car. Can somebody IM me with this info.
Thanks,
Tim
Old Aug 29, 2002 | 12:59 PM
Kamin's Avatar
Default Re: 2000 Civic Si radio code (NVMYSi)
you need to call a local honda dealer and give them the vin number off your car and the radio
you may need to bring it in to them
each owner picked a security code when the car was origionally purchased.
Old Aug 29, 2002 | 02:13 PM
MASTRCHANN's Avatar
Default Re: 2000 Civic Si radio code (KAMiN)
try mine... 25311
it's worth a shot. oh wait, you only get three tries. NM.
Old Aug 29, 2002 | 02:35 PM
NVMYSi's Avatar
What a kick in the nuts!!!! Will just the vin # be enough or do I need to take the radio out to get the # offf that also? I may as well put a new head unit in if I have to take this on out to get a serial #.
Old Sep 1, 2002 | 05:52 PM
YumVTEC's Avatar
They won't be able to give you jack with the Vin of your car. You have to get the serial # off your radio. Some dealers will write the code on a sticker on a hidden location in your car somewhere. Call and ask the svc dept you got your car from if they follow that practice. Otherwise you'll have to take out your radio and get the serial # off it and take it to the dealership so they can get you the code.
Old Sep 1, 2002 | 06:04 PM
Gump's Avatar
Default Re: 2000 Civic Si radio code (YumVTEC)
Look inside your glove compartment, there is a white sticker in there with the radio's serial number, call the dealer and tell them you need the radio code, and give them the serial number printed on the sticker, they should be able to give it to you, and if they tell you that you have to pay, just IM me with the serial number, and i'll get it for you.
Old Sep 1, 2002 | 06:29 PM
NVMYSi's Avatar
Default Re: 2000 Civic Si radio code (Gump)
Gump,
I will try contacting a local Honda dealer on Tuesday (holiday weekend), I did locate the sticker in the glove box. If they don't help me I will IM you with the info.
Thanks
Old Sep 1, 2002 | 07:06 PM
cleanASScoupe's Avatar
OMG Gump, u just saved me sooo much trouble. I never knew about the sticker and i just checked and it has the serial number AND the 5 digit code. Thanks....
NVMYSi, u sure there wasnt a 5 digit code on that sticker?
Old Sep 1, 2002 | 07:09 PM
Ya@inlinePRO's Avatar
you shouldn't have to take out the radio, just bring your car to the dealer with the proof of ownership, (title) and they should be able to take care of it. but yea, call them up first.
Old Sep 1, 2002 | 07:10 PM
SicK's Avatar
Damnit, double posted.
[Modified by SicK, 4:12 AM 9/2/2002]
Old Sep 1, 2002 | 07:11 PM
SicK's Avatar
My stereo has been off for 3 months because i have no code.I have the serial number on a sticker in my glove box, just like you said. But no code for the stereo.Could you please get my code for me, too?
code = M98F318715
NVMYSi's Avatar
Default Re: 2000 Civic Si radio code ('99EJ8)
The sticker that I located had both numbers and leters on it and some of the numbers were higher that 6 so it most likely isn't the radio code. I've never had to pull the radio on this car, how hard can it be its a Honda.
Old Sep 3, 2002 | 01:18 PM
NVMYSi's Avatar
Gump,
You have IM, thanks
elplatanodomin
Aug 17, 2008 08:53 PM
fi76sh
Feb 19, 2006 08:58 PM
acuradrivr
Audio / Security / Video
Sep 20, 2004 01:54 PM
