Car isn't STARTING!!!
the brass piece is one piece pressed in if you are missing the middle it broke. rotor bad. white stuff probably a little calcium buildup like you get on your battery from water getting on it check the little rubber gasket that goes around your dist. and the square one around the wires.
Unjockable
20
Feb 15, 2004 03:49 PM
