What mounts, Clutch and Flywheel are recommended for EK H2B swap
Old Oct 15, 2009 | 05:24 PM
H2B-EK4's Avatar
Default What mounts, Clutch and Flywheel are recommended for EK H2B swap
hi
im doing a h2b in my ek
orginal plan was to use an evolution industries kit but after reading some problems ppl have had with these i think im gona go for QSD.
I have an EK4 with a b16a2 in there from standard but i dont think these stock mounts are good enough and want better mounts, what mounts do ppl recomend? do i need to look for ek b series mounts or ek h swap mounts?
also what clutch and flywheel are recommended, i want a lighter flywheel than stock b-series
My enggine is a h22a7 euro-r engine, im aiming for around 220whp. The car will be used a s a dialy driver but dont mind something which i have to get used to but dont want no extreme stiff mounts and hard clutch either
Thanks
Old Oct 15, 2009 | 07:28 PM
Puma909's Avatar
Default Re: What mounts, Clutch and Flywheel are recommended for EK H2B swap
Hey there. A few of my friends run the Bisimoto H2B kits (Bisimoto and Evolution collaboration) with out any problems. Most used Action Clutch which has soft to stiff clutches. Even those that utilized other brand clutches have not had any problems with the Bisi H2B kit. I personally use a stock flywheel right now. My brother and his best friend use the Bisimoto flywheel. I don't know much info about them but from what I understand they are made of billet aluminum and are very light. As far as mounts, both of the mention kits come with mounts that fit very snug (no need to elevate the hood on ek or eg chassis'; it won't alert thieves). I hope my answer was helpful.
Old Oct 16, 2009 | 02:37 AM
H2B-EK4's Avatar
but if i go for QSD what mounts shuould i use?
is the any specific clutch or flywheel brand model?
thanks
Old Oct 16, 2009 | 03:43 AM
H2B-EK4's Avatar
im looking to get fidanza flywheel what weight shall i get?
i can only find 7.5-9 lbs which is too light, what weight is recommended and will an excedy stage 2 clutch be fine with it.
Old Oct 17, 2009 | 01:54 AM
H2B-EK4's Avatar
im gona be getting an ACT street lite 12.5 lbs flywheel what clucth is recommended, mostly road use, daily driver, ecu will be set up for launch control, and f=few visits to 1/4 strip?
thanks
Old Oct 17, 2009 | 10:37 AM
sciamutanna's Avatar
Use Hasport mount or Innovative mount
Maybe you can use the Energy Suspension insert, but Hasport and Innovative is bettere way.
For the flywheel use the Clutch Master specific for the H2B use. They work whitout the qsd spacer.
For the axles use the DSS 2.9
The H22A7 is the better H-series engine.
Old Oct 17, 2009 | 11:09 AM
H2B-EK4's Avatar
hi what do u mean by axles. Im using b-series driveshafts. What clutch should i use. Looking at act or competion stage 4 6 puck sprung any good. Car wil be daily driver with a few 1/4 runs
Old Oct 18, 2009 | 01:15 PM
H2B-EK4's Avatar
bump
Old Oct 21, 2009 | 06:03 AM
NABeastRR's Avatar
no need for dss axles just use stock B axles.
ive launched at 8500 on stk ones countless times u just have to know how to preload.the fact that youll barly do 1/4 racing id deff not worry about it.
Momentum
10
Sep 17, 2010 11:01 PM
SPOON_BeIgHtEeNsEe
Jul 8, 2004 07:01 PM
Snipes69
Nov 3, 2002 08:31 PM
