Can you turbo a b20?
Old Oct 15, 2009 | 01:15 PM
nightshift's Avatar
Default Can you turbo a b20?
It's in a 1996 hatch. What turbo should I get?
Old Oct 15, 2009 | 01:20 PM
h23darkprelude's Avatar
Default Re: Can you turbo a b20?
im not to sure about the best turbo size but iv heard of b20s being beasts if there done right
Old Oct 15, 2009 | 01:26 PM
ferio252's Avatar
Short answer yes. You can turbo anything. Don't know what kind of Turbo you want but it all depends on the tune I guess.
Old Oct 15, 2009 | 01:37 PM
eg grom's Avatar
Do you have the vtec head, because you might wanna think about getting that before you turbo.
Old Oct 15, 2009 | 01:51 PM
Arcitekt's Avatar
MOB Mentality
check that you have a vtec head and being that its a b20 are you considering any internals?
Old Oct 15, 2009 | 02:03 PM
nonpoint986's Avatar
ANother thing you might want to consider is putting arp head studs AND MAIN STUDS!! It really helps hold the bottom end together. Even for the turbo. I have a sc61 turbo for my b20/v havnt installed it yet, someone before me had it on his ls/v and said it pulled like a son of a b****
Old Oct 15, 2009 | 02:09 PM
eg94hbcivic's Avatar
New User
boosting it about 10 pound on stock parts would be safe
Old Oct 15, 2009 | 02:12 PM
HackeN's Avatar
What's the build of the engine? It all depends on your build & goals. Is it a straight B20 or a B20/Vtec?
As stated before in this thread, you can turbo anything. Be sure your motor is healthy though if you're leaving it 'stock'. Start w/ a leakdown test or compression check before you even do anything & check how the numbers look.
Old Oct 15, 2009 | 02:13 PM
EFbomb's Avatar
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
read this
holleratchaboi
Apr 24, 2008 09:07 PM
TakumiFujiwara
Aug 15, 2003 02:48 PM
TakumiFujiwara
Aug 15, 2003 02:47 PM
rocket_R
Aug 24, 2002 11:06 AM
