Vibration while Decelerating and in Reverse
The other day I was reversing out of my garage and I heard/felt this quite loud vibration in the front left wheel area and it shakes the whole front end, then while I was driving I started to decelerate without braking and it vibrated just as bad as when it was in reverse. I just replaced my driver side axle and the problem still persists. Im not sure if its the wheelbearing, lower ball joint or clutch/throwout bearing?
Also check for any wiggle room between your axle and the shaft.
i have that prob, just no time ti fix it...
well i just replaced the cv joint.. I mean I know there is a possiblity that the new one is bad. Also it happens when im not even in gear say if i hit a big enough bump it'll vibrate and it sounds like a thumpthumpthumpthump + vibration. I've had this problem before I just cant remember what it was or how I fixed it, probably 3+ years back
GRM Scott
Sep 22, 2012 07:13 AM
FormulaIntegra
19
Jul 4, 2009 09:28 AM
Philip
14
Dec 4, 2005 08:41 AM
01, 2006, accord, civic, deccelerating, decelerate, decelerating, deceleration, engine, loud, reverse, shakes, vibrate, vibrates, vibration
