b20b intake manifold is to big for the engine bay!!!!
Old Oct 14, 2009 | 05:27 PM
JDM.EG's Avatar
Default b20b intake manifold is to big for the engine bay!!!!
im doing a b20b non vtec swap in to my 93 civic hatch!
the stock intake manifold is way tooo big to fit under the hood,
i have already lifted the back of the hood up about 1in and if i were to make it any higher it would look funny.
what intake manifold do i use because the bolt pattern is odd?
HELP
Old Oct 14, 2009 | 05:30 PM
speedooo's Avatar
Default Re: b20b intake manifold is to big for the engine bay!!!!
an ls manifold should work
Old Oct 14, 2009 | 05:33 PM
R666_EK's Avatar
Yeah that IM is huge. The "giraffe". Just pick up a B20z or LS IM. They go for pretty cheap.
You could also run a B16 or Type-R but those usually go for more.
Old Oct 14, 2009 | 06:04 PM
98civdx's Avatar
Master Detailer
ls will work just fine.
Old Oct 18, 2009 | 05:14 PM
JDM.EG's Avatar
would i be able to use one from a 2000 si.
i have a 1990 ls one but the bolt pattern is wrong for it.
and can i sue the b20b throttle body on an ls one?
Old Oct 18, 2009 | 05:22 PM
vtechjunkie's Avatar
I saw the guys @ Rywire just milled the intake @ an angle. This brought the top of the manifold down a bit. I don't know how much you need ot to come down but..... Check out the build thread he started and see what he did. Then you don't have to worry about the tb not fitting. This was a K into a crx btw.
Old Oct 18, 2009 | 06:22 PM
unusual71's Avatar
VTEC and Non-VTEC intake manifolds are not interchangeable
i think throttle bodies are all the same though
Old Oct 19, 2009 | 04:55 AM
speedooo's Avatar
vtec doesnt make a different, it's in the head casting. P72, PR3 and PR4 heads need different manifolds
Old Oct 20, 2009 | 05:21 PM
JDM.EG's Avatar
will the b20b throttle body fit on a 96 ls intake manifold?
Old Oct 20, 2009 | 05:25 PM
98civdx's Avatar
Master Detailer
the b20b is smaller then the ls. i think it will fit but i would not use it.
Old Oct 20, 2009 | 05:28 PM
Deetz's Avatar
Crazy Honda Guy
I wouldn't bother with the LS manifold, don't know why so many people say to do it. The B20Z manifold off the 99-01 model makes better power, i have 1st hand experience with this with a swapped EK. Clearance is good too!
billcass
Apr 9, 2010 06:31 PM
mingchi69
Sep 5, 2003 07:39 AM
