Suspension & Brakes Theory, alignment, spring rates....
benen tie bar question
Old Oct 14, 2009 | 03:02 PM
icucnme's Avatar
Default benen tie bar question
I have a chance to buy a used benen rear tie bar for my 94 integra. My question is with that tie bar can my oem rear sway bar still be used with no modifications? Anyone have a picture of theirs mounted?
Old Oct 14, 2009 | 03:33 PM
variable's Avatar
Default Re: benen tie bar question
The Benen Tie bar mounts to the sub frame below the sway bar, no modification needed, it simply bolts right up. You can retain your stock suspension.
Here is a great thread with plenty pics of rear tie bar set ups
https://honda-tech.com/forums/showth...hlight=lca%27s
Old Oct 14, 2009 | 03:39 PM
icucnme's Avatar
Awesome thanks for the quick response. I was not 100% sure since it's off the car. Is 45 dollars a good price for it?
Old Oct 14, 2009 | 03:59 PM
variable's Avatar
Sounds good to me (sight unseen). Just jack up the rear of the car and it should bolt right up. If you have ABS, you may have to move the rear abs lines around a bit. I cant remeber for sure but I think I had to when I installed by Beaks bar on my GSR .
Old Oct 14, 2009 | 04:01 PM
icucnme's Avatar
It was only on my friends car for like a month then he went with the full asr setup. Yeah I have abs but I'll figure it out. Might just try and turn a profit. lol
redlinexd
Suspension & Brakes
Jun 20, 2010 01:49 PM
square_1
Sep 21, 2008 06:16 AM
dohcroc
Suspension & Brakes
10
Feb 6, 2005 10:50 PM
TW00Si
Apr 3, 2002 09:49 AM
