wiseco 11:5 gsr block portflow head jdm itr tranny
Old Oct 14, 2009 | 03:01 PM
runum4lifekid's Avatar
Default wiseco 11:5 gsr block portflow head jdm itr tranny
PRICEEEEEDROPPPPPPP on head and longblock
LOCATED IN ORANGE COUNTY NY, 1 hr from bronx, 1 hr from jerzzz, 1 hr from conn.
up for sale is my built b series THE BLOCK OR TRANNY and a coupla small parts left
fully built jdm gsr head, all work done by PORTFLOW in cali.
comes with PORTED skunk2 Intake manifold vtec seleniod, brand new honda cam seals, valve cover, and Hondata Intake manifold gasket...has just over 2,000 miles
-3 angle valve job
-full race port and polish
-.005 taken off the deck of the head to freshen it up/make compression a little tighter
-new valve seals
-supertech mid strength valvesprings
-supertech flat valves
-supertech retainers
-ehxhaust ports ported and polished
-intake ports ENLARGED for more airflow, and ported and polished.
-skunk2 intake manifold comes with the head because the im was also ported to match the openings on the head
HEAD IS SOLDDD SOLDDDD SOLDDDDD
fully built jdm gsr block, has just over 2,000 miles
-block was taken to machine shop, cleaned hot tanked honed to make sure the new rings seated perfectly, and the rotating assembly was balanced, all bearing clearances were checked, crank was polished
-weiseco 11:5:1 compression pistons, with new rings
-eagle h-beam rods
-acl race bearings
-arp head studs
-brand new oem acura water pump
-brand new oem acura oil pump
-gates timing belt
-ctr crank pulley
-jdm itr 12 pound flywheel
-act 6 sprung 6 puck clutch
-act pressure plate
-$1500
-99 spec jdm itr tranny with the 4.7 final drive and LSD, with password jdm magnetic drain bolt new 3rd gear synchro installed last year
it has SKUNK2 PRO1 cams, cam gears, a ported SKunk2 intake manifold,
tuned on NEPTUNE p28, in my bubble it went 13.4 @ 102 on street tires, (have slips to prove) easily a 12 sec. setup
--JDM ITR TRANNY alone--$900 FIRM
--COMPLETE SHORTBLOCK-$1500
Old Oct 15, 2009 | 03:29 PM
Default Re: wiseco 11:5 gsr block portflow head jdm itr tranny
bumppp for a nice b series all motor saleee
Old Oct 16, 2009 | 06:12 AM
Jtbelcher's Avatar
would love to have this :\ stock jdm itr swap or this hrmmmm
Old Oct 16, 2009 | 02:41 PM
if i were u im tellin u this motor has pulled all over 2 jdm itr motors with bolt ons in bubbles im talkin bus lenghts just from second to fourth gear rolls...im not bullshittin this motor is fresh no smoke ready to be dropped in and pull hard as hell...i have videos of my 2400 pound bubble goin 13.4 on STREET TIRES! stock r motor will have u stuck in the mid 14s
Old Oct 17, 2009 | 07:52 AM
bumpooo
Old Oct 17, 2009 | 02:21 PM
all looks no bumps for a fully built b
Old Oct 18, 2009 | 01:40 PM
Jtbelcher's Avatar
u have a sn? and ud prob get more interest if u didnt just have 10 posts
Old Oct 18, 2009 | 02:38 PM
lluks_844's Avatar
I can vouch for this man. Legit Guy.
Old Oct 18, 2009 | 04:51 PM
killerpenguin21's Avatar
the motor is as fast as he says it is.
hes just being a a bitch and getting rid of it since mine is faster
gonna miss the little bus.
Old Oct 18, 2009 | 07:59 PM
lengualoco21's Avatar
Bump i seen motor n car first hand nice Bseries setup. btw its about time u step up to teh bnig leagues K time lol!!!!
Old Oct 19, 2009 | 08:51 AM
Jtbelcher's Avatar
you got aim?
Old Oct 19, 2009 | 03:59 PM
thanx for the vouches guys! yah my screename is mydreameclipse07...dont laugh at the name i havent used aim in a minute
Old Oct 19, 2009 | 04:01 PM
the only reason i have only 10 posts is cuz i havent been on here in a few months and the site totally g'd me on my name and password so i had to create a new one
Old Oct 22, 2009 | 02:14 PM
bumppp for the built b series sale
Old Oct 22, 2009 | 06:58 PM
pricedrop on head and longblock
Old Oct 22, 2009 | 07:04 PM
C-Rex1021's Avatar
Bump for the OC and a nice motor
Old Oct 23, 2009 | 12:16 PM
bludevil2982's Avatar
Damn if only you were located a lil closer to the midwest I'd take that tranny of your hands ! But Glws !! Bump !
Old Oct 23, 2009 | 05:59 PM
ryan...you still suck.
but bump anyway.
Old Oct 23, 2009 | 07:45 PM
thank you nate...u suck too my man lmao
bump
Old Oct 25, 2009 | 01:23 PM
JDMCIVICMAN1992's Avatar
Bump for sparking interest in my pops for his shell. He'd like to see dyno sheet. can you post?
Old Oct 26, 2009 | 02:24 PM
yah i can post it up...ill have it up tomm.
Old Oct 26, 2009 | 04:11 PM
if you still have any of this come spring, i will take it off your hands since ill have my sign on bonus by then.
watch out for the new sfwd motor coming soon...oh and another 15whp outta my 1.8 ;-)
BUMP
Old Oct 27, 2009 | 12:35 PM
daam boy sounds like u got serious plans comin out next year....if i got any of it left by then (which im hopin not) its urs
Old Oct 27, 2009 | 02:23 PM
Heres the dyno sheet, it made 196whp 136ftlbs of torque. motor would have put out 5-10 more if my exhaust did not go from 2.5" down to 1.3/4" back to 2.5" near axle back...the exhaust was under the car for so daam long i totally forgot that it did that on the curve toward the axle back...whatchya gonna do though
Old Oct 28, 2009 | 06:09 PM
bumpooo
