00 dx swap
Old Oct 14, 2009 | 02:32 PM
hopalong's Avatar
Default 00 dx swap
so i finally bought a swap for my 00 dx hatchback. i bought a B16A2 FULL SWAP, ENGINE,5SPD TRANS,ENGINE HARNESS,ECU,SHIFT LINKAGES,MOUNTS,AXLES from a 00 civic si. so my question is...do i need anything else for this swap?
i use the si rear tranny mounts and driver side mount, drop in the engine, hook up the si engine harness to the si ecu. hook back all the miscellaneous goodies and start the engine. is it that simple? im hoping that i can do the swap this weekend. im also gonna change the tbelt, waterpump, thermostat, valve cover gasget, clutch and replacing the belts.
im new here and this is my first honda swap. so any advice or tips will be greatly appreciated!
Old Oct 14, 2009 | 07:42 PM
hopalong's Avatar
Default Re: 00 dx swap
anyone?
Old Oct 16, 2009 | 09:54 AM
hopalong's Avatar
so im starting today! i did the belts, clutch etc this week so all i have to do is remove my old engine and get on my way
Old Oct 16, 2009 | 12:18 PM
Lasky's Avatar
sounds like you have everything you need and yes it is that simple (its a honda) and good idea on the maintenance before it goes in, much easier to change that stuff when the motor is still out of the car..
have fun with vtec but the torqueless action will get annoying after a while, i want to supercharge my B16 now for torque!!
Old Oct 16, 2009 | 12:20 PM
R666_EK's Avatar
You seem to have it all under control. Very straight forward. Good luck. Swaps are always fun!
Old Oct 16, 2009 | 06:31 PM
hopalong's Avatar
update! well the shop forgot to pack the shift linkage so i had to drive 1 hour each way to get it. so they gave me innovative motor mounts from another engine swap they had for free, for my inconvenience! cant wait to put them on! i got home and i took out the engine in about 2 hours...and i was taking my time. no bolts gave me any problem...i cleaned the engine bay with soap and water and did minor wire tucks. im taking pics so after the swap is complete ill post them up!
Canadian_EF
Jul 11, 2009 01:14 PM
opera936
Dec 8, 2007 10:07 PM
dropd4door
Jan 25, 2003 09:38 PM
