FS:N/A BUILT JDM B18C LONG BLOCK
Old Oct 14, 2009 | 12:52 PM
EG-2slo's Avatar
Icon5 FS:N/A BUILT JDM B18C LONG BLOCK
MOTOR IS FINISHED AND IS IN MY 93 SOL RIGHT NOW. ONLY DROVE A LITTLE BIT FOR BREAK-IN PURPOSES NEVER GOT ECU CHIPPED OR TUNED RAN OUT OF MONEY. TRYIN TO GET BACK ON TRACK WITH BILLS AND **** ! SERIOUS BUYERS PLEASE!!
JDM B16A HEAD:
HOT TANKED NO PORT OR POLISH
SKUNK PRO SERIES 2 CAMS
SKUNK PRO SERIES DUAL VALVE SPRINGS AND TITANIUM RETAINERS
NEW HONDA VALVE SEALS
FACTORY VALVES
AEM ADJUSTABLE CAM GEARS "OLD SCHOOL"
BRAND NEW DISTRIBUTOR WITH MSD CAP AND EXTERNAL BLASTER COIL
HONDATA IMG
STOCK 00 SI INTAKE AND THROTTLE BODY
AEM FUEL RAIL
AEM ADJUSTABLE FUEL REG.
RC 370CC INJECTORS
AFTER-MARKET ITR HEADER
COMETIC HEAD GASKET
ARP HEAD STUDS
NEW SEALS, GASKETS
JDM B18C BLOCK:
HOT TANKED
BORED .020 OVER
BLOCK GUARD
JE 12:5:1 PISTONS 81.5MM DIA.
JE RINGS
JE PINS AND LOCKS
CROWER RODS STOCK LENGTH
EAGLE 4340 CRANKSHAFT STOCK STROKE
TYPER OIL PUMP,WATER PUMP,TIMING BELT
ITR PULLEY
NEW TIMING BELT GEAR AND KEY
MOROSO OIL PAN
ALL NEW BEARINGS, SEALS, AND GASKETS
I THINK THATS IT. I GOT MOST OF THE RECEIPTS. AND MOST OF THE PICTURES FROM THE BUILD. ILL TRY MY HARDEST TO FIND THEM ALL. I DID A COMPRESSION TEST USING MY SNAP-ON COMP TESTER AND ITS GIVEN ME READINGS OF 295-300PSI ACROSS THE CYLINDERS. NEVER REGISTERED CAR BUT SOUNDS STRONG AND FELT GREAT JUST BOMBIN AROUND TOWN. MAYBE 300 MILES ON MOTOR.
ASKING 3K PLEASE NO LOW BALLER STUFF THIS IS A NICE LEGIT CLEAN ENGINE!!!
IF YOUR REALLY INTERESTED CALL ME OR TEXT AT 774-930-4412 ITS JUST EASIER FOR ME IM NEVER HOME. MY NAMES DAN THANKS ALOT FOR YOUR TIME GUYS!
ADD 650.00 IF YOU WANT 00 SI TRANNY AND ACT STG 1 CLUTCH AND LIGHTWEIGHT FLYWHEEL
Old Oct 14, 2009 | 12:55 PM
EG-2slo's Avatar
Default Re: FS:N/A BUILT JDM B18C LONG BLOCK
HOW CAN I POST MORE PICTURES?
Old Oct 15, 2009 | 07:16 AM
EG-2slo's Avatar
bump... tryin to figure out how to put up some more pics for you guys??
Old Oct 16, 2009 | 11:05 AM
EG-2slo's Avatar
is there a reason why no ones helpin me out on this one!!! i just want to know how i can post more than 5 pictures ?!?!?! i have about 5 more id like to put up so poeple can see this motor for **** sake!!
Old Oct 16, 2009 | 11:50 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
type this....
[img] then post your web address of picture here [/img]
Old Oct 17, 2009 | 03:37 PM
EG-2slo's Avatar
[img]http://photos-d.ak.fbcdn.net/hphotos-ak-snc1/hs263.snc1/9016_1214742099886_1568826258_583211_4106808_n.jpg[img] [img]http://photos-c.ak.fbcdn.net/hphotos-ak-snc1/hs243.snc1/9016_1214742259890_1568826258_583215_647857_n.jpg[img] [img]http://photos-b.ak.fbcdn.net/hphotos-ak-snc1/hs263.snc1/9016_1214742139887_1568826258_583212_6658507_n.jpg[img] [img]http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs243.snc1/9016_1214742299891_1568826258_583216_5325217_n.jpg[img] [img]http://photos-h.ak.fbcdn.net/hphotos-ak-snc1/hs263.snc1/9016_1214742179888_1568826258_583213_1429411_n.jpg[img]
Old Oct 17, 2009 | 03:38 PM
EG-2slo's Avatar
[img] http://photos-d.ak.fbcdn.net/hphotos..._4106808_n.jpg [img]
Old Oct 17, 2009 | 03:40 PM
EG-2slo's Avatar
[img] http://photos-d.ak.fbcdn.net/hphotos..._4106808_n.jpg [/img]
Old Oct 17, 2009 | 03:41 PM
EG-2slo's Avatar
Old Oct 17, 2009 | 03:45 PM
EG-2slo's Avatar
thats why they call it dope!
Old Oct 18, 2009 | 05:15 PM
EG-2slo's Avatar
bump.. bringin the motor with me saturday to import wars if anyone wants to check it out it'll be there!!
Old Oct 20, 2009 | 11:31 AM
EG-2slo's Avatar
everyone looks but noone helps me out with bumps.. come on meow!
Old Oct 20, 2009 | 04:25 PM
CrxRex's Avatar
bump
Old Oct 21, 2009 | 01:36 PM
JdmOdz's Avatar
bumppppss
Old Oct 24, 2009 | 04:02 PM
EG-2slo's Avatar
Icon7 Re: FS:N/A BUILT JDM B18C LONG BLOCK
bump... still 3k would like to add a garuantee that motor will start and produce 60-80 psi of oil pressure and 280-300 psi of compression per cyl. i also will perform the swap for an extra $200 if buyer needs help! price is not negotiable, motor is 100% ready to go! please call or txt with questions 774-930-4412 the first person to find a better buy then this gets a night with the wifey!! hehe hope she dont see this..
Old Oct 26, 2009 | 04:22 PM
EG-2slo's Avatar
buuuuuuuuuuuuuuuuuump!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Oct 26, 2009 | 04:30 PM
Skunkduce's Avatar
Bump Cleann motor
Old Oct 27, 2009 | 06:32 AM
EG-2slo's Avatar
thanks for da bump!
Old Oct 29, 2009 | 11:54 AM
EG-2slo's Avatar
yaaaaaaaay! starting new job next week keeping my engine now so mods you can delete this shiz!!!!!!!!!!!! ooooooooooooaaaaaaaa!! ooooooooooooooaaaaaaaaaaaaaa! postin dyno results as soon as shes in the new coupe!! muahahahaha!
Donkey-Punch
Mid-Atlantic (Sales)
Sep 1, 2012 02:50 PM
johnson_racing
13
Mar 22, 2009 08:11 PM
B20VTI
Oct 19, 2006 04:37 PM
