should i upgrade intake manifold and throttle body?
Old Oct 14, 2009 | 12:51 PM
gosu08's Avatar
Default should i upgrade intake manifold and throttle body?
i am thinking about upgrading intake manifold and throttle body on my current setup.
currently i just have a t3/t4 turbo on my ITR (stock motor) @ 11lbs putting out 340whp.
i currently have on stock ITR manifold and throttle body (68mm or 70mm?) and am wondering if upgrading will give me any significant gains (15+ hp)?
or if anyone knows how much it should help would be great and suggestions on manifold and throttle body would be great as well.
i dont want to go out and spend 500+ dollars for a minimal gain of less than 10hp.
thanks
Old Oct 14, 2009 | 07:27 PM
97CWITR's Avatar
Default Re: should i upgrade intake manifold and throttle body?
Why not just turn up the boost 2lbs?
Old Oct 15, 2009 | 12:19 PM
gosu08's Avatar
my thats the safest amount of boost i can run on my motor on 91 octane.
i am going to up it later in here soon when i change to e85.
just wondering if i should do these upgrades to get more gains before i go get the retune or if its minimal gains then i wont and save my money...
Old Oct 15, 2009 | 12:24 PM
red_crx's Avatar
On a stock motor..those upgrades would be a waste of money; Just turn up the boost if you want more power.
Old Oct 15, 2009 | 12:26 PM
gosu08's Avatar
ok thats good to know. thanks. i dont want to waste hundreds of dollars for less than 15hp
Old Oct 15, 2009 | 12:27 PM
red_crx's Avatar
are you running a 3" exhaust?
Old Oct 15, 2009 | 12:31 PM
gosu08's Avatar
yes im running 3" exhaust
Old Oct 15, 2009 | 01:04 PM
Gregg00R's Avatar
You would def. notice a difference if you got the manifold and throttle body because you are obv. increaseing the air flow but on the other hand you would want to get your car retuned for theses modifications. Also what size injectors are you using?
Old Oct 16, 2009 | 10:33 AM
WheaMyRyceGo's Avatar
If your going to get an intake manifold and tb, you should get the head ported as well to maximize gains.
Old Oct 17, 2009 | 09:52 PM
gosu08's Avatar
Yeah I'm running 1000cc Bosch injectors. I'm just going to keep everything stick and just tune for e85 and hopefully be able to get close to maximum potential of my turbo.
Thanks all!
bloodline_ls
Mar 31, 2005 09:19 PM
JforJonathan
10
Apr 10, 2004 12:15 PM
done
Sep 30, 2003 08:47 PM
