b18c1 / ls build.....new young learner
Ok boys heres my situation
i have a 91 gs 5 speed...i was going to do a full gsr build ( p 72 ) to be right....well i have the the gsr bottom block cleaned and ready but now i dont think im getting my head so now my question is this....
my boy has a ls Non Vtec head p&p and after marked cams....
Q. can i put this head on my gsr block or use another head....and what else would i need as far as intake and throthel body and ECU....my car is OBD0
Q. now if i want to do a full GSR Vtec Swap what would i need as far as parts. axsels , ECU, ect.ect. i know i can use the stock tranny that came with the car and im not sure but i saw that i can use a jumper to use the p72 ecu pls any help would be nice me
Q1: Yes you can put it on, you would need a LS.Vtec kit (golden eagle) makes it. You could use your stock parts, and you would use a ls ecu... chip it if you are going to use a head with work done to it...
Q2: You would need some gsr axles (pending year differences), p72 ecu (or = such as ctr,si,itr -single stage intake ecu though)
Advice: Don't do LS.V... They cost just as much to build as a gsr swap basically, and you get a crap power band.
What i would suggest doing is... GSR Swap, with LS crank (eliminate oil squirters), CRV crank pulley, ITR/CTR99-00 cams, and a edlebrock (performer x) intake manifold, ctr/itr ecu, and that's all i can think of...
I don't really mess with Honda/Acura anymore since i went VW... but i still knew/know my stuff :D
also... have a 520whp civic hatch as a toy <3 soon to be @ 700+ mark
Think he was thinking you were using a ls block with a gsr head which is commonly known as "ls.v", when in reality you are talking about the doing opposite, which makes his advice about Q.1 irrelevent.
totally agree but iits nice to know how to do it......so do you have any input on what im trying to accomplish...thanks
