another o2 sensor diagnoses
Old Oct 13, 2009 | 06:21 PM
slow96lude's Avatar
Default another o2 sensor diagnoses
Ok so I have the Infamous CEL 41. The problem I have with that is that it kickes on as soon as I start the car. And the ecu shouldnt even be looking at it untill the car warms up. I have tested the o2 sensor PER/ Helms and Haynes and it checks out. I also made sure that the sensor is getting power, and it is. My really dumb question is. Is there any fuses that could have went bad.
Old Oct 14, 2009 | 05:28 AM
slow96lude's Avatar
Default Re: another o2 sensor diagnoses
TTT
so someone can look at it
Old Oct 14, 2009 | 12:14 PM
slow96lude's Avatar
35 views and no suggestions. I have found that there arent any fuses that would control my sensor. Im just going to get another and see what happens
Old Oct 14, 2009 | 12:23 PM
Former User's Avatar
Code 41 indicates a problem in the circuit for the O2 sensor heater element. Have you done all of the electrical tests for code 41 in the service manual? For example, does the heater element of the O2 sensor have the proper resistance (10-40 Ohms)? Is there continuity to body ground at either heater element terminal in the unplugged O2 sensor connector?
Old Oct 15, 2009 | 05:07 PM
slow96lude's Avatar
The bold part i didnt do. I have the correct ohms. And Im getting power to the sensor from the harness.
randomracing
Dec 26, 2008 08:37 AM
claytonsmith
10
May 16, 2006 12:01 PM
apok
May 16, 2005 09:52 PM
cu3tip
Oct 18, 2004 08:26 PM
CereaLand
Jun 30, 2004 12:01 PM
