How Can you Inspect Timing Belt in Honda Accord 1994
Hello Honda Gurus,
I have Honda Accord 1994 EX with 191000 miles do not have any record or history of the Car about the repair i-e about Timing Belt can any one please tell me that How can you visually Inspect or check timing belt that does it need replacement or not any help will be greatly appreciated!!!!!,
regards,
FS
regards,
FS
Just based on the year and mileage it's about due for another timing belt. Since you don't know when it was last done I wouldn't leave it to eyeballing it. The whole 7 years, ~80k miles thing is what I went by. And you're overdue on both. The timing belt should be preventative maintenance and not resultant maintenance (think I made this term up haha)
I'd suggest going the safe route and have the major service done along with fluids (coolant, brake, ps, abs, etc)
Yup, the visual inspection would not be good enough. Best bet is to do it. Could you possibly ask the owner you previously bought it from if he has done it or knows when it has been done?
resultant is a new word....so says themuffinman...now we need to get it added to websters......but yes you are overdue for a timing belt either way ....and whether you decide to tackle the job yourself(gonna guess not) or take it to a shop.....better get the following done:
water pump
head gasket
timing belts
tensioner
valve cover gaskets w/ spark plug grommets
power steering belt
alternator belt
would be a bad idea to have the intake manifold gasket done either (upper and lower)
all fluids as muffinman said
brake flush
pcv valve and fuel filter(whenever i do timing change i do these 2 as preventative as a rule of thumb)
if you treat your honda right it will run forever
water pump
head gasket
timing belts
tensioner
power steering belt
alternator belt
brake flush
RA022626
Jul 2, 2015 10:39 AM
shrekfiona
17
May 31, 2013 11:04 PM
