CivicR Pistons
anyone of you guys running the PCT B16B on a b16a motor?
according to c-speedracing.com the compression with these will be 10.8, everything else stock.
opinions wanted!
opinions wanted!
yup, no different than running a b16b motor ... call it a cheap man's b16b (b16a with ctr pistons and ctr cams).
I've done it many times and milled as much as 30 thous to get compression really up there, pumped out about low 190's at wheels on a customers b16a.
Greg
Greg
Greg
i was thinking just about that! dropping the CTR cams and pistons, with a 2 layer spoon gasket for starters. i could also consider milling the head a bit.
what rpm can i safelly do with some the ITR valve springs?
CTR cams give power up to about 8500 rpms, the ITR valvesprings will have no problem with that.
with CTR pistons and a thinner head gasket you should yield about 11.5.1 compression
if everything is dynoed correctly you will be looking at about 170-180 whp
according to c-speedracing calculator, the compression with CTR pistons and 2 layer gasket should be 11.1...
i was thinking of doing 9300rpms..
I wish I had witnessed what people say happens with Jun 3's they say it snaps timing belts yadda yadda.. but if you engine is midily built I wouldn't run anything more than Jun 2's it will make sufficent power for a street car
sprayin95hatch
Jul 24, 2005 08:43 PM
Driven
14
Apr 4, 2004 10:58 PM
