b18a1 no spark
Old Oct 13, 2009 | 03:46 PM
93ls-civic's Avatar
Default b18a1 no spark
alright i did a resistance test on every plug on my harness and ecu all of them are 0 resistance, i changed all the internals in the dizzy still no spark i am at a total stand still on what to check now.
can anyone please help me? i miss driving this beast lol
Old Oct 13, 2009 | 04:14 PM
93ls-civic's Avatar
Default Re: b18a1 no spark
and what is the resistance suppose to be in the spark plug wires? when i tested mine it was 1.984 could that be the problem or is that normal for stock wires
Old Oct 13, 2009 | 04:19 PM
Former User's Avatar
Does the fuel pump prime? Is the CEL on? Any CEL codes?
Does the Blk/Yel wire attached to the coil and igniter unit have battery voltage witth the key in ON(II)?
Did the timing belt snap?
Old Oct 13, 2009 | 04:27 PM
93ls-civic's Avatar
pump primes the wires are conected and getting power to them and the timing is spot on
Old Oct 13, 2009 | 04:34 PM
With the key turned to ON(II), does the CEL remain on or turn off after 2 seconds.
What voltage do you measure at the Yel/Grn wire attached to the igniter/ICM?
Does the Yel/Grn wire running between the ICM and the ECU lack continuity or have a short?
Old Oct 13, 2009 | 04:38 PM
93ls-civic's Avatar
"cel" whats that stand for?
and i believe we were getting 12 volts
Old Oct 13, 2009 | 04:41 PM
Click here.
Check the Yel/Grn wire for an open or short. If the wire is fine, try swapping in a known good ECU.
Old Oct 13, 2009 | 04:49 PM
93ls-civic's Avatar
ok the cel comes on when in aux key pos number 2 then goes off after a few seconds.
i swaped out the ecm with a p28 that still didnt make a change
Old Oct 13, 2009 | 04:57 PM
Are both the coil and igniter unit new?
If so, check the Ye/Grn wire. If that's fine, measure the resistance for each of the three distributor sensors.
Old Oct 13, 2009 | 05:02 PM
93ls-civic's Avatar
both are new from shucks with .003 to .000 resistance.
what is the resistance suppose to be between the spark plug wires? i was getting 1.984 on mine is that what they are suppose to be at
Old Oct 13, 2009 | 05:09 PM
Check the Yel/Grn wire.
What are you measuring and what are the units?
Plug wires should have 25 kilo-Ohms max.
Old Oct 13, 2009 | 05:12 PM
DB1_559's Avatar
how did you check ur timing belt ???? are you sure the parts are working inside the dist?everytime i get a no spark is the coil acting up....have you tryed a new distrubutor from a running car ????
Old Oct 13, 2009 | 05:45 PM
93ls-civic's Avatar
alright i will have to check that in a little bit
Old Oct 13, 2009 | 05:49 PM
93ls-civic's Avatar
i took the crank pully off an liiked at the mark an it was all tdc, al the internals are brand new as of today, and i bont have a spair one might have to hit up the craigslist tonight an see what i can find
Old Oct 14, 2009 | 03:20 PM
93ls-civic's Avatar
i went to shucks and got a dizzy and the motor fired right up, wtf?. its running really rich now to could that be due to it not running in 3 weeks? my check engine light is on with codes 16 injectors, 7tps, 2 o2 sensor, and 12 egr
k20z1ej1
May 26, 2017 12:00 PM
97honda civic dx
18
Apr 12, 2009 06:41 AM
floored4door
14
Dec 15, 2006 07:12 AM
ipleadthe5th
Sep 12, 2004 06:02 PM
