z6 turbo OVERHEATING! HELP PLZ
I just swapped a z6 with turbo into my car. it would overheat when it ran for awhile but go back down once i started drivin. I already replaced the water pump and thermostat.. still overheats then cools back down(intermitting) when i turn the car off the coolants boilin back into the the resivour? Any help id appreciate it. Thanks H-T
whats done to the motor as far as the headgasket/headbolts or studs?
id take a good gander and say your having headlift, which the sohc engines are known for once they see some sort of FI. had the same problem when i was spraying and it'll get worse as the more you drive it.
Hoosier Daddy
Feb 25, 2004 11:16 AM
Nextelbuddy
25
Feb 18, 2004 11:12 AM
