Mint 1998 Civic Coupe setup for Auto-X/Road Racing
Old Oct 13, 2009 | 10:55 AM
torbs's Avatar
Default Mint 1998 Civic Coupe setup for Auto-X/Road Racing
Number: (701)-361-8658 --> I prefer you call/txt
Price: $4900/obo
OLD HONDA-TECH ads of the car:
http://hondamarketplace.com/showthread.php?t=2079263
http://hondamarketplace.com/showthread.php?t=2387470
More (older) pics...Car is basically the same.
EXTERIOR:
SiR Bumpers (OEM)
SiR Lip (OEM)
SiR Headlights with City Lights (OEM also have stock ones with yellow d)
CTR Thin Side Moldings (OEM)
 CTR Front Grill (OEM)
Antenna block off plate (OEM), Black Rota Slipstreams with like new tires, OEM DX 96-98 tail lights, tow hooks on both front and back for road racing
INTERIOR:
POR15'd The Floor/Trunk
Rest Is Painted Battleship Grey
Sound Deadening material is removed.
Personal Neo Grinta 350mm.
MOMO Steering Wheel Hub
. Stock EK seats. Buddy Club Quick Shifter.
SKUNK2 shift ****.
Radio Block Off (OEM).
Master Kill Switch/Key
. Carbon Kevlar Fuel Pump Cover.
EX model Amber cluster with the original DX speedo swapped over to keep mileage.
Amber climate control as well; matches the cluster perfectly(both use the same bulbs).
Mild rear wiretuck.
Removed SRS system (everything)
POWERTRAIN:
Stock D16Y7 motor/trans. 138k miles. Tanabe Stainless B-Pipe
Cusco Exhaust Hanger Bushings.
Avid Racing Hard Billet Torque Mounts
. Stainless Steel Clutch Line. Project Kics Magnetic Oil Drain Bolt
. Clutch and Brake Fluid Bled (Motul)
. Re-grounded with 6G Wire.
Relocated Fuse Box (Under Glovebox).
Mild Wire Tuck (Headlight Harness, Grounds, Brackets Removed)
. Aftermarket header.
Brand new battery, starter and new ground wires.
SUSPENSION:
Buddy Club N+ Adjustable Coilovers (re-valved to fixed rate/non adjustable)
. Function7 Rear LCA's
. ASR Rear Tie Bar (Polished).
ASR Rear 22mm Swaybar.
Function7 Endlinks
. Mugen Rear Trailing Arm Bushings
. SRR Camber Arms
. SRR Toe Adjuster Arms
. Civic HX Front 22mm Sway Bar
. Civic HX Front LCA's
. H-brace
Weight: 2080lbs with a FULL tank of gas...Near empty it's under 2000lbs.
This car is 100% rust free, and is as nice as you will be able to find. Cosmetically, only a couple dings, primarily on the hood. Overall though, great shape. It's an absolute Auto-X beast. Let me know if you have any questions.
Torbs
Old Oct 13, 2009 | 11:47 AM
Chester Rumble's Avatar
Default Re: Mint 1998 Civic Coupe setup for Auto-X/Road Racing
When did GhettoSi sell this car?
I miss this car a lot, except for the gutted interior. Even with the SOHC I was faster than a couple of EVO's and an STI at the only autocross I did in it before selling it. It was definitely a beast.
Old Oct 13, 2009 | 12:52 PM
obeyphysics's Avatar
Bump cause I looked, and I liked!
Old Oct 13, 2009 | 01:12 PM
typac69's Avatar
bump
Old Oct 14, 2009 | 11:46 AM
B Dap's Avatar
Just asking for a B Swap! Sick car!
Old Oct 14, 2009 | 12:06 PM
Grip's Avatar
nice coupe!
Old Oct 14, 2009 | 01:05 PM
kozanatos's Avatar
Never heard of por15... Checked it out and thats ownagggeee
Old Oct 14, 2009 | 01:25 PM
Fantastic420's Avatar
Sick sh*t. GLWS.
Old Oct 14, 2009 | 03:42 PM
Eg6Matt's Avatar
Great coupe!
Old Oct 14, 2009 | 03:50 PM
real_slow_EM1's Avatar
wow sick and great price!
Old Oct 14, 2009 | 10:14 PM
Any newer pictures of the car? All of those pictures except the last one are from when I owned the car.
Old Oct 15, 2009 | 10:19 AM
torbs's Avatar
Car is the exact same except it no longer has the Spoon N1, has a Personal wheel instead of a Nardi, has 96-98 taillights, no rollcage, has tow hooks on front and back, stock ek seats, and has amber gauges/climate control with tach.
I don't have any current pics of the car, but it looks the same as what it did then aside from what is mentioned above. Has black Rota Slips on it so it looks very similar to what it did with the Spoons on it.
Any other questions?
UP
Old Oct 15, 2009 | 02:43 PM
UP
Hahaha I know what the car does and doesn't have. GhettoSi bought the car off of me and I'm assuming he sold it to you. Or it changed hands a few more times before you bought it.
I was just trying to get a read on where the car has been and how it looks now since I sold it.
Old Oct 15, 2009 | 03:04 PM
torbs's Avatar
I believe I'm the 3rd owner since GhettoSi. And it's as I have described it...so not really anything has changed.
Old Oct 15, 2009 | 04:32 PM
That's crazy. I'm blown away that it still has the D-series in it.
Old Oct 15, 2009 | 05:51 PM
BoOsTeD[BaRnEy]'s Avatar
bump those bumpers r sick jdm
Old Oct 15, 2009 | 10:00 PM
torbs's Avatar
bump!
Old Oct 17, 2009 | 02:52 AM
torbs's Avatar
TTT
Old Oct 17, 2009 | 12:37 PM
torbs's Avatar
bump
Old Oct 20, 2009 | 12:14 AM
torbs's Avatar
up
Old Oct 21, 2009 | 03:00 PM
torbs's Avatar
TTT
Old Oct 21, 2009 | 05:19 PM
importdreamer's Avatar
bump cuz i looked. Then I saw the pictures and thought it looked familiar. I've ridden in this beast!! Pretty solid car!
Old Oct 21, 2009 | 07:48 PM
vinmotors's Avatar
*bump. Pm your price without wheels if not glws.!
Old Oct 21, 2009 | 08:03 PM
xkrazyxjbrkerx75's Avatar
damnnn.. def worth the priceeee
Old Oct 21, 2009 | 11:59 PM
AkAKumar's Avatar
