94 civic automatic to manual torque bars
Old Oct 13, 2009 | 10:28 AM
x_doug-x's Avatar
Default 94 civic automatic to manual torque bars
i got a 94 civic hatch and i want to bolt the torque bars on the engine side and tranny side, do they sell a bolt on conversion or what do i need?
Old Oct 13, 2009 | 11:43 AM
boxeocampeon's Avatar
Default Re: 94 civic automatic to manual torque bars
check online search it under google
Old Oct 13, 2009 | 12:46 PM
x_doug-x's Avatar
i'm not finding anything.. do they even make torque mounts for a auto to manual b series conversion? it was originaly a automatic d16 i guess and it's been converted to a manual lsb18 the integra torque mounts dont work.
Old Oct 13, 2009 | 03:43 PM
94EG8's Avatar
Seagull Management
Reuse the original civic rubber mounts (doesn't matter if they were from an automatic or a manual, both are the same) with the B-series metal brackets.
Old Oct 13, 2009 | 04:20 PM
x_doug-x's Avatar
ok, i have the integra metal bracket for the b18 transmission on the transmission, however the torque peace is not on the round part i had to remove it, the round part that holds the rubber bushing is sitting flat against the metal frame i can't get the rubber torque mounts on it.
Old Oct 14, 2009 | 05:21 PM
94EG8's Avatar
Seagull Management
What did you use for an upper transmission mount? Sounds an awful lot like you used a 5 speed upper mount with the stock automatic pocket mount thats welded to the frame rail, this will cause the engine to sit at an angle. If this is the case you need to buy an aftermarket auto to manual conversion mount, or cut off the automatic pocket mount and weld in the corresponding manual version.
STRAIGHT-H
Jun 19, 2019 08:50 AM
Jhicks
14
Apr 25, 2012 09:00 AM
chinochanginc
Jul 24, 2008 01:01 PM
