Precision 6262 dyno 683 whp 2.0 VW
Old Oct 13, 2009 | 07:39 AM
lugnuts's Avatar
Default Precision 6262 dyno 683 whp 2.0 VW
I had been trying for months to find a dyno of a 6262 turbo on a Honda making big power, but could only find cars tuned to ~500 or so.
We dynoed this car, so i figured i would post it here for people to compare to.
VW 16v, 2.0l, stock head, mild cams, E85 fuel, 2x044 pumps, Bosch 160# injectors (ugh Tony??? lol) thru an air filter and a full 3" exhaust with a resonator and muffler. Turbo is a 6262 with a .63 AR.
683 whp at 40-38 psi, and 437 whp at WG spring 18-22 psi.
Old Oct 13, 2009 | 09:10 AM
Tjabo's Avatar
Default Re: Precision 6262 dyno 683 whp 2.0 VW
That is awesome! Thanks for posting! ! ! ! !
Old Oct 13, 2009 | 09:28 AM
AFI Turbo's Avatar
Looks good! i have one going on my Evo... What was duty cycle on the 1600's and base fpr if you dont mind me asking?
Old Oct 13, 2009 | 11:54 AM
lugnuts's Avatar
Fuel pressure is 4 bar static, and Duty Cycle was riding 85%, it's time for ID 2000's!!
Tuned to .79 lambda. How does that compare to your numbers?
Old Oct 13, 2009 | 02:04 PM
tony1's Avatar
Did a car last week with ID2000's on E85. Made 655whp with 50psi base FP and 68% duty cycle, running .78 lambda or so.
Oh, and that was at 9k rpm.
Old Oct 13, 2009 | 02:37 PM
Tjabo's Avatar
That's some VERY impressive duty cycle! However, aren't those injectors prohibitively expensive?
Old Oct 13, 2009 | 02:42 PM
tony1's Avatar
They are more expensive than most. Everyone has to make that determination on their own.
4 Bosch 1600's and injector driver or 4 ID2000's.
Night and day difference in idle quality and driveability, power, and cylinder to cylinder consistency. More power potential. Less parts to fail (no injector driver or resistor needed).
What's it worth in the end?
Old Oct 13, 2009 | 03:42 PM
Tjabo's Avatar
Yeah, good points. I guess it probably all falls under the heading of "Gotta pay to play!"
Old Oct 13, 2009 | 04:10 PM
95civhb's Avatar
do you have any details as far as the block? Just wondering what they had for a setup??
Old Oct 14, 2009 | 07:16 AM
Mark Morris's Avatar
Factory ABA block with rods and pistons.
Old Oct 14, 2009 | 10:02 AM
B20luda's Avatar
probably carry torque a bit better with a .82 housing...
lots of power
Old Oct 14, 2009 | 10:23 AM
Tjabo's Avatar
Hypothetically speaking, how much later would you expect it to make boost on a motor like this?
Old Oct 14, 2009 | 12:47 PM
Whatever's Avatar
I've never seen an old school 16V VW motor make that kind of power. What type of engine management is it using? Makes me miss my old 86 GTI that had a 2.0 16V swap in it...
Old Oct 14, 2009 | 01:35 PM
lugnuts's Avatar
Neither have I, lol, and I went 9's back in the day with a 16v.
Its using my "Lugtronic" brand VEMS ecu. $1200 bucks, includes a wideband, EGT, boost and idle control, great datalogging, etc.
The car is a real street car with air filter and exhaust. it gets driven to work a few days a week.
We might try the .82 and some more cams over the winter.
Old Oct 14, 2009 | 01:53 PM
Lugtronic.
Old Oct 14, 2009 | 02:29 PM
D-Rob's Avatar
I had no clue there was a local Volkswagen guy that did EFI tuning.
I'm PM'ing you regarding some things.
- Derek
Old Oct 14, 2009 | 10:29 PM
JFK78's Avatar
Nice, a ton of power, esp. for an old VW!
Since you said you'd been looking and couldn't find any higher power honda charts for a SC6262, here's one we did a few months ago, pretty basic setup on less than 30psi. Still one of my favorite turbos!
631whp/448tq @ 28psi only revving to 8300rpm
84mm lsvtec, 9.0:1 c/r, CTR cams, Victor X, SC6262S .82 a/r.
Old Oct 15, 2009 | 04:12 PM
Tony the Tiger's Avatar
Really nice powerband on that thing!
Old Oct 15, 2009 | 06:07 PM
VtecCarHauler's Avatar
6262 is awesome along with the E85!
Old Oct 16, 2009 | 12:10 AM
DUB20VT's Avatar
Awesome power ....!!!!!! What was the ignition timing at ? Any plans to test a 6765 out ?
Old Oct 16, 2009 | 05:31 AM
Kevin is not only a local VW guy, he is THE VW tuning guy.
Old Oct 16, 2009 | 05:33 AM
Would you be so kind as to post-up your D-Series 6262 chart please?
Old Oct 16, 2009 | 09:01 AM
Innes's Avatar
we put a 6765 on the race car about 4 weeks ago - 2.0L GSR engine
T4 with 0.82 A/R
made 760 whp at about 35 psi (sorry no dyno graph to post)
but it had a great powerband, it is still on the car now actually, not sure how much more power we can get out of it with the current setup, can't make as much boost on the b series engines with it as you can the 4g63 engine for instance, those guys are making big power with the 6765
bang for the buck these precision billet turbo's seem to do a real nice job
Old Oct 16, 2009 | 07:38 PM
JFK78's Avatar
Sure, same exact turbo as the chart above, but on a 75mm D16 instead of a 84mm LSVTEC:
609whp/404tq @ 30psi
Old Oct 17, 2009 | 04:09 AM
JDM97R's Avatar
SC6262 here LSvtec 81mm @30psi 630hp 427lb on Q16
