troubleshooting code 15 1990 honda accord ignition output signal
hi somone plz help me
k i got a 1990 honda accord and my car turns off after a while(when it gets hot) i pulled up this trouble shooting code 15 the ignition output signal.. my car wont stay on!! what do i do??? it has to be ignition problems its not burning the gas or something cause i can smell gas when i drive it but theres no leaks... what do i need to check or replace and how plz help me
Code 15 usually is the igniter.
Refer to this link:
http://techauto.awardspace.com/ignition.html
"ECU code 15: Code 15 is listed as an error in the "Ignition Output Signal." If you have this code it means that the ECU has found the Ignition module (igniter) signal is not received by the ECU which means that the igniter is dead, has a loose connection or has failed intermittently. The ECU looks for the 10V reference signal from the igniter. If the car won't start because of this code then check for a loose connection or go to section 4 on this page and be ready to replace the igniter..."
Refer to this link:
