code 15-1
Old Jul 22, 2018 | 10:47 AM
kens1802's Avatar
Default code 15-1
code 15-1
Old Jul 22, 2018 | 11:36 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: code 15-1
What year and model vehicle?
Old Jul 22, 2018 | 03:51 PM
kens1802's Avatar
1994 Honda accord 2.2
Old Jul 22, 2018 | 05:38 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1. What is the issue?
2. Generally, ABS or SRS codes 15-1 does not apply to a '94 Accord. Which leads to the next question.
3. Which indicator light is giving the trouble code?
Old Jul 23, 2018 | 01:14 AM
kens1802's Avatar
Snap on scan tool
I went back this morning and read my scan tool again. Error code 15-1
I don't believe the scan too code is right
Also I did use the dash also to confirm on the dash I get error code 15
Which indicates to me ignition control module so I did do all the test for voltage all good.
So is it possible that ignition control module is bad. But before I get 1 , MY question is will the car sill fire and start for a second and die right out.
Old Jul 23, 2018 | 05:54 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Code 15 usually is the igniter.
The following is from the now defunct Techauto page:
"ECU code 15: Code 15 is listed as an error in the "Ignition Output Signal." If you have this code it means that the ECU has found the Ignition module (igniter) signal is not received by the ECU which means that the igniter is dead, has a loose connection or has failed intermittently. The ECU looks for the 10V reference signal from the igniter. If the car won't start because of this code then check for a loose connection or go to section 4 on this page and be ready to replace the igniter..."
Old Jul 23, 2018 | 04:34 PM
Camile Howerton's Avatar
Hi Tech8 where is the "Section 4" you are referring to? Or where is the thread where your original paragraph was posted Thank you for your help. Camille
Old Jul 23, 2018 | 06:15 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That site (techauto.awardspace) is long dead. An alternative, the "Wayback Machine" (internet archive) did not capture the images related to that section; so, it won't be of any real help.
There are many guides on the web on testing the ignitor (aka ignition control module (ICM)) though.
zccr-xsi
Nov 4, 2005 10:36 AM
kuteboi
Jan 29, 2005 09:11 PM
lilcasino
Oct 23, 2004 11:03 AM
CiViC SiR
Jul 4, 2003 02:24 PM
CBR600OnTop
Jul 3, 2003 01:14 PM
