FS : 95mm Scat Crank!
HONDA FORGED 4340 STANDARD WEIGHT CRANKSHAFTS
Standard weight forged crankshaft is designed for
street or race engines with substantially increased horsepower. . . . features
• Straight shot & chamfered oil holes,
• Nitride hardened for superior wear reisistance,
• Lightening holes in all rod throws,
• Large radius on all journals,
• Precision ground, heat treated,
shot peened, inspected & micropolished at SCAT
• Designed at SCAT
• Engineered at SCAT
• Finish machined at SCAT
• Finish grinding at SCAT
• Heat treated by SCAT
• Inspected & micropolished at SCAT
This crankshaft will give you plenty more torque in which ever B series motor you decide to put it in! Especially if you are building a motor and dont want to take the risk of boring it out. The is the perfect alternate! I am selling ONLY because i need the money. Otherwise, i would rape face with it. Recommended for all motor applications..For boost applications i would recommend some drag radials at the LEAST! do your research. This is a steal!
600 obo!!
• Designed at SCAT
600 obo!!
