Piece-0-Crap..
Old Oct 12, 2009 | 07:12 PM
Fatty Wagovan's Avatar
Default Piece-0-Crap..
I went to take the door sills of and this is what i found. The Bolts Are Striped. What should I do???
Sorry for the crappy pics.
Old Oct 12, 2009 | 07:28 PM
crx_si-r's Avatar
Default Re: Piece-0-****..
you can try this product. its pretty much a bunch of nails in a socket that form itself to whatever shape it slides over. its like that square that has a bunch of nails and you can imprint your face, hands or fist to it.
Old Oct 12, 2009 | 07:40 PM
fdcusa's Avatar
They aren't stripped -- it's a 6-sided sunken style screw/bolt. You need a driver that has the same size 6-sided "Star" bit to get it off.
Old Oct 12, 2009 | 07:44 PM
johnnyonth3spot's Avatar
just checking, you do know that a torx bit is required for that rite? I have to ask because they have some real tards on here and its really hard to strip the head of a torx.
Old Oct 12, 2009 | 07:46 PM
crx_si-r's Avatar
they look stripped from the pictures that were posted
Old Oct 12, 2009 | 07:47 PM
I cant tell I just see a dirty blury bolt. Try shocking the threads and use a new bit if that doesnt work drill and easy out.
Old Oct 12, 2009 | 07:48 PM
~sp33~'s Avatar
EFB055
Looks like you could use an alan key in there.
Old Oct 12, 2009 | 07:53 PM
crx_si-r's Avatar
or take a dremel and a cutting disk. then notch a straight line and use an impact screw driver to knock it loose. like the ones you use on rotor screws when they are stuck in the rotor.
Old Oct 12, 2009 | 08:02 PM
bmanuhutu's Avatar
Yup 2x above... piece of cake :D
Spray PBlaster let it soak overnight.. and get 'ur done.
Old Oct 12, 2009 | 08:22 PM
D16SiHatch's Avatar
holy out of focus! lol
Old Oct 12, 2009 | 08:28 PM
michael-crxsi's Avatar
good job just have him cut a groove out of a perfectly good bolt. i have to say i feel the the dremal is my most used tool some days lol
Old Oct 12, 2009 | 09:30 PM
Does any one know what size it is?
Old Oct 13, 2009 | 04:11 AM
crx_si-r's Avatar
Look at the edges, in the inside where the t45 or t50 torque bit would go. With the provided pictures they look stripped. I know what type of bolt it is. Op provide better pics
oneprelude
Mar 20, 2010 01:14 AM
pa_itr
Dec 10, 2007 12:15 PM
idriveadelsol7
Welding / Fabrication
17
May 8, 2005 09:09 PM
CHiNkStEr
Mar 5, 2005 07:35 AM
G2turbo_terror
Jul 1, 2003 11:46 PM
