EK from B to D Mounts Question?
Old Oct 12, 2009 | 02:13 PM
trooper0641's Avatar
Default EK from B to D Mounts Question?
Ok here's the thing I dont know anything about EKs and was not aware that their mount setup is different from EF/EGs. The EK use to have a b-series swap in it (gsr).. the "b-series rubber mounts" are still installed on the chassis. I'm going to put a sohc d16y8 back into it.. and was wondering if the "rubber mounts" from the past b-series swap are usable with the sohc swap. At the moment I am missing the "EK SOHC motor mount brackets for each individual mount" & I can't tell if the rubber peices are any different.
I am missing**
23190 #007 1 BRACKET, RR. ENGINE MOUNTING (REAR TRANNY T BRACKET)
23186 #004 1 RUBBER ASSY., ENGINE SIDE MOUNTING (THE BRACKET FOR DRIVER SIDE MOUNT)
23189 #006 1 BRACKET, TRANSMISSION MOUNT (MT)
Old Oct 12, 2009 | 02:54 PM
raidacaipo's Avatar
Default Re: EK from B to D Mounts Question?
No they are not interchangeable. You need all those parts you listed as missing and then you need some motor mounts.
asocallocal
Apr 11, 2008 10:28 PM
JDMrasta
Aug 5, 2007 07:26 PM
redEH2
Sep 5, 2005 01:49 PM
SyDuck
Jan 28, 2005 06:59 PM
FritzInTN
Jan 20, 2004 08:04 AM
