clutch still has play after bleedn it. SUGGESTIONS?
Old Oct 12, 2009 | 12:45 PM
brewski's Avatar
Icon6 clutch still has play after bleedn it. SUGGESTIONS?
Last night i posted up that i was having issues with my hatchs clutch pedal having to much play. I bled the clutch and read the haynes manual just to make sure i was doing it right. the clutch does come back now after pressing it but still doesnt feel like my coupe. any help would be great.
Old Oct 12, 2009 | 12:49 PM
Simkin314's Avatar
Default Re: clutch still has play after bleedn it. SUGGESTIONS?
Check your pedal height adjust. Keep bleeding.
Have you put an aftermarket clutch in?
STOCK_SOHC_DX's Avatar
Maybe you need a new master?
Old Oct 12, 2009 | 12:53 PM
brewski's Avatar
have no idea if there was an after market clutch installed.
Old Oct 12, 2009 | 01:01 PM
Simkin314's Avatar
I had to bleed my clutch long after I thought I needed to. New clutch master may help. Aftermarket clutch should make it stiffer. Clutch height adjust shouldn't help but its worth checking. Clutch slave cylinder...
Old Oct 12, 2009 | 01:02 PM
gwl's Avatar
gwl
I have a two Civics, both are 97's (coupe and hatch) and clutch pedals feels different between the two. I can't figure out why they feel different. At least it shifts without any problems.
Old Oct 12, 2009 | 01:04 PM
brewski's Avatar
all suggestions will be looked into. thanks guys.
Stonage07
Mar 6, 2017 11:48 AM
Kyle244R948
Nov 26, 2008 01:25 AM
tvman
Jul 16, 2005 11:30 AM
SiYouLater
May 23, 2004 11:35 AM
