Lous Suspension
Hey everyone.
I drive a 1995 Honda Prelude, SR-V (si Vtec). Its lowered on Koni Yellows, and Tein Springs. Whenever I go over bumps, it sounds extremely loud inside the car, both front and back, so i doubt its shock knock.
I checked everything, end links, ball joins, bushings, everything is okay and tight. even pulled out the front shocks before and checked them and they were okay.
I'm stumped and have no idea what could be causing this, everytime I hit a bump, its very loud and shakes everything inside the car, almost as though the shock assembly is moving and hitting the car, but its not.
Anyone have any other ideas as to what could be causing this?
also check out your sway bar end links they tend to make some crazy noise when they go out..just pull up and down on them and see if they "click" or just check all your bushings and such
Civic4less
Apr 23, 2005 09:05 PM
