Squeeky Noise on Bumps?? What is it?
I get a pretty squeeky noise whenever I go on a bump or on a bumpy terrain. I thought I could handle it but it's beginning to get REALLY annoying. It seems to be coming from the front right section of the car. Anyone know what it could be?
Re: Squeeky Noise on Bumps?? What is it? (Civic4less)
Tie rod, ball joint, etc etc.... some piece of your suspension. Crawl under your car and see whats really worn out.
blown shock? check to see if its leaking oil, you'll be able to see it and smell it on your finger..
shock boot (some are plastic) and will rub on the spring when you hit a bump
sway bar ( after market bars tend to squeak if the bushing isn't lubed up
start there
start there
