Problem at Cold Start
Old Aug 29, 2002 | 06:41 AM
EF8_SiR's Avatar
Default Problem at Cold Start
It's not a severe problem but I don't know why it's happening. When my car has been sitting for more then 10 hrs (say overnight) and I go to start in morning, it hesitates big time (sounds like it's very slowly igniting - rpms really low and i have to hold key in start position for at least 3+ secs).
On a warm start though, it starts up perfectly fine.
Any ideas?
Old Aug 29, 2002 | 09:53 AM
Louie B.'s Avatar
Default Re: Problem at Cold Start (EF8_SiR)
I'm experiancing a similar problem so I'll give you a *bump*
My engine is a D15B1 w/ mpfi swap
I'm assuming by your name that yours is a B16A ?
Old Aug 29, 2002 | 11:10 AM
xXsarcasmXx's Avatar
Default Re: Problem at Cold Start (thumpu77)
Im having the same problem!! errr!! I have a b16a......
....help.......please.....
Old Aug 29, 2002 | 11:13 AM
raene's Avatar
Have you tried priming the pump before starting? Hold the key in the on position for two seconds, and then try to start. See if that helps.
Old Aug 29, 2002 | 01:22 PM
Perfectionist's Avatar
Cold starts require more fuel and a higher idle. Inspect the fast idle valve if you've got one. That would take care of the higher idle. The TW sensor and IAT sensors should tell the ECU the engine is cold, so I would check those out next.
CamboSoup562
Apr 6, 2010 06:42 AM
civicb16eg
12
Mar 3, 2009 11:56 AM
busyychild
May 11, 2007 05:13 AM
jizzer671
Dec 18, 2005 01:39 PM
accord_se
Dec 31, 2004 10:22 PM
