Lost fuel pressure...maybe? Help!
Old Oct 10, 2009 | 10:52 PM
MHDesigns's Avatar
Default Lost fuel pressure...maybe? Help!
So my car has no other issues except this. Any time the gas cap comes off, It takes me like 45 seconds of cranking for it to start. It seems as if I may be losing pressure or something. I have a walboro fuel pump and I think its working good.
There is no fluxuation in fuel pressure at the rail, however this only happens if I take the cap off and refill. The car can sit for 2 weeks without issues but when the cap comes off I get stuck cranking... Anyone ever had a problem like this? The only real problem is, I look like a jerk cranking my car forever at the pump. Any other time it starts right up, no issues.
Old Oct 11, 2009 | 12:30 AM
eg grom's Avatar
Default Re: Lost fuel pressure...maybe?
Man there's a sensor on the back of the block that I once had go bad and I had completely lost fuel pressure, but I can't remember what it was called if it comes to me I'll let you know, but if you know which one I'm talkin about definently check that out.
Old Oct 11, 2009 | 12:35 AM
MHDesigns's Avatar
well i only have the problem when I re-fuel. Other than that it's good. It's like starting a car that just ran completely out of gas.
Old Oct 11, 2009 | 12:52 AM
eg grom's Avatar
You might just wanna think about getting a new gas cap. I'm shootin in the dark with this one, but I'd try getting a 2.00 cap before I started trouble-shooting with sensors and regulators.
Old Oct 11, 2009 | 12:56 AM
MHDesigns's Avatar
Cap seems fine. The system is still pressurized when I open the cap. I guess it seems as if it just takes forever to get pressure after re-capped. Maybe my fuel pump? The car runs strong all the time though...I dunno. Any help appreciated.
Old Oct 11, 2009 | 11:57 AM
MHDesigns's Avatar
bump
Old Oct 11, 2009 | 12:56 PM
MHDesigns's Avatar
Anyone else? lol Nobody else has ever had, or heard of someone having,this issue?
Old Oct 11, 2009 | 05:53 PM
connorslaunwhite's Avatar
whenever i fill my car above 3/4, it barely wants to crank over (b20b). when it does it'll bubble in the rev's from 250 - 500rpm then i give it some gas to wake it up!! other than that its fine. haha ive just learned to never fill it above 3/4 so i dont sit there ****ing with the ignition.
Old Oct 12, 2009 | 09:36 PM
MHDesigns's Avatar
Thats what mine does except on any fill. Even if I just take the cap off and then put it back on... Anyone else had this problem? Anyone know how to fix it...My car has enough character....
Old Oct 12, 2009 | 09:42 PM
slow96lude's Avatar
I know there is another thread on this somewhere. Im waiting on RonJeremy@HT to Chime in on this....LOL Because I believe he was the solution to that problem
Old Oct 12, 2009 | 09:44 PM
MHDesigns's Avatar
Yeah Ron is a pimp and helped many times....Where are you Ron!?!?! lol
Old Oct 13, 2009 | 12:12 AM
MHDesigns's Avatar
bump
Old Oct 13, 2009 | 05:22 AM
joelmatt89's Avatar
Default Re: Lost fuel pressure...maybe? Help!
does it do it if you just take the gas cap off but don't refuel. When did it start doing this. Was it abrupt or is it getting worse.
Old Oct 13, 2009 | 06:50 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
pop the cap off, put it back on, and cycle the key to ignition (prime the fuel pump) about 5 times, then try to start car...
did it fire right up?
Old Oct 13, 2009 | 03:57 PM
MHDesigns's Avatar
Thanks, Worked fine. Does this mean my fuel pump sucks? It's a walboro unit almost 6 months old.
Old Oct 13, 2009 | 04:08 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
when did the problem begin?
Old Oct 13, 2009 | 04:16 PM
MHDesigns's Avatar
less than a month ago
Old Oct 13, 2009 | 05:31 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
did it happen out of the blue, or did it follow something?
Old Oct 14, 2009 | 12:52 AM
MHDesigns's Avatar
Out of the blue, just got gas one day and had to crank forever...what are you getting at?(Not being rude, just want to know what variables your running through your head cuzz i'm lost)
Old Oct 14, 2009 | 12:56 AM
eg6_trust's Avatar
CHECK THE FUEL PUMP FUSE UNDER UR STEERING WHEEL ITS A 15 MABEY IF U PUT A LIKE NUMBER 20 FUSE IT WILL GO AWAY THAT WAT MY CAR DID AND I CHANGE IT AND I DONT HAVE ANY PROBLEM IF NOT IT MIGHT BE THE SENSOR IN THE BLOCK THATS WAT I THINK
Old Oct 14, 2009 | 01:01 AM
MHDesigns's Avatar
What sensor on the block? Anyone got a name for this so called sensor?
Old Oct 14, 2009 | 04:52 AM
R666_EK's Avatar
I can't think of any sensors on the block that would have anything to do with fuel.
Knock, Oil, Coolant...
I'm only guessing, but it could be a leak in the EVAP system. Purge control or vent.
Old Oct 15, 2009 | 08:30 AM
MHDesigns's Avatar
FOR THE WIN! Purge line was cracked. New line and it's fixed. Thank you very much everyone for the help.
Old Oct 15, 2009 | 02:59 PM
R666_EK's Avatar
Congrats on the fix!
Old Oct 15, 2009 | 03:51 PM
Former User's Avatar
Nice call R666_EK. I didn't have any good ideas on this one.
EFn-DirtySouth
19
Apr 5, 2014 04:24 PM
b_boysaiyan
Jan 20, 2014 11:41 PM
*DRE*
Oct 4, 2011 11:13 PM
w00ted
May 8, 2009 07:56 AM
Magick211
Oct 30, 2004 10:28 PM
