Transmission & Drivetrain Gearboxes, Differentials, Clutches
ECU for d16z6 manual trans conversion
Old Oct 10, 2009 | 04:21 PM
moknoy's Avatar
Default ECU for d16z6 manual trans conversion
Just wanna know what compatible or best ecu that will work for a D16z6 when doing a auto to manual trans conversion?
Or if someone can direct as to where i can have my P28 auto trans ecu reprogrammed to work for the manual set up?
Thanks!
Old Oct 10, 2009 | 05:02 PM
94EG8's Avatar
Seagull Management
Default Re: ECU for d16z6 manual trans conversion
If you can solder the info below should help you out.
Old Oct 10, 2009 | 08:24 PM
moknoy's Avatar
Do you have the close up view of the soldered part? You remove a diode off the rp18 and replace it with only a jumper wire?
Old Oct 11, 2009 | 04:46 AM
94EG8's Avatar
Seagull Management
Sorry, thats the best picture I have right now. you have to remove both RP17 and RP18, both are resistors, then replace RP18 with only a jumper wire.
Old Oct 11, 2009 | 04:26 PM
moknoy's Avatar
IC! Got it! So that eliminates the cel for the trans solenoids?
And thanks i meant resistors. lol
Old Oct 11, 2009 | 05:24 PM
94EG8's Avatar
Seagull Management
Sure does. I'm running an automatic P28 converted that way In my '93 Si right now, no CEL
No problem
Old Oct 11, 2009 | 06:26 PM
moknoy's Avatar
Very helpful tip. +1 for you.
Old Oct 12, 2009 | 01:58 PM
moknoy's Avatar
Do you have a chip on your ECU?
Old Oct 12, 2009 | 05:16 PM
94EG8's Avatar
Seagull Management
Nope. Just a bone stock automatic P28 converted to manual. Previous owner swapped in a P06 ECU for some reason that was chipped and converted to Vtec (poorly I might add, and it never worked right)
Old Oct 13, 2009 | 04:23 AM
moknoy's Avatar
I see! Well if it worked as stock based id rather do that.
Thanks very much!
JUN
1 Fly SI
Engine Management and Tuning
Nov 30, 2008 05:30 PM
Suck my DX
Aug 26, 2006 02:06 PM
CRISIS
Feb 5, 2006 09:20 PM
90AccordVTEC
Oct 12, 2005 11:27 PM
kinghawk
Jun 16, 2005 02:41 PM
