B16 EG, runs ok on stock p28, doesn't on chipped p28
Old Oct 10, 2009 | 12:57 PM
TheRobotSpy's Avatar
Default B16 EG, runs ok on stock p28, doesn't on chipped p28
I have a 95 EG hatch with a B16 swap. The car runs, and revs fine on a stock p28, but when I put a chipped p28 (just chipped for b16) in the car it starts and idles fine but as soon as the throttle opens it bogs and will not rev. Any ideas on what could be causing this?
Old Oct 10, 2009 | 03:19 PM
civicracer1997's Avatar
Default Re: B16 EG, runs ok on stock p28, doesn't on chipped p28
You may want to double check the tuning on your chip. You may by chance have a SOHC chip in your ecu by mistake. The p28 will run either SOHC or DOHC engines.
Old Oct 10, 2009 | 03:21 PM
93egSLEEPER's Avatar
needs to be tuned? it hasnt been tuned for the afr and basemap at WOT yet. the stock p28 at least has a factory tune.
Old Oct 11, 2009 | 06:13 PM
I just bought the ECU with tune from phearable.
Old Oct 11, 2009 | 06:59 PM
gsrhatch2356's Avatar
it is bad, nothing more to say. one works and the other dosent. problem solved.
Old Oct 11, 2009 | 08:02 PM
dohcdelsol's Avatar
ive seen both hit and misses from phearable.net if the one you got from them is the b16 chipped and it isnt running, id send it back to them and tell them what is going on.
EJ SIR
14
Feb 19, 2009 01:55 PM
ivan93egreppin210
Dec 12, 2008 05:51 PM
erasable180
11
Mar 11, 2006 08:57 PM
sporty240
Jul 20, 2005 10:25 PM
B6teen
Apr 25, 2005 01:39 PM
