prelude h23
Old Oct 10, 2009 | 12:47 PM
777DYNASTY's Avatar
Default prelude h23
i have an h23 bored .020 over sleved and low compression pistons 9:1 and i am wanting to boost anyone who can help that would be great. i was wondering how much boost i could run? and how much boost if i have a 50 shot of N2O or if i should take off the N2O?
Old Oct 11, 2009 | 04:36 AM
street_ride14's Avatar
Default Re: prelude h23
if you are properly sleeved , you can run whatever horsepower // psi you want. Be realistic though. The weak point now is switched from your block/piston to your fuel/ignition. Many people run your block setup to 500-600whp on pump gas and stock ignition .. on Boost.
Old Oct 11, 2009 | 10:11 AM
777DYNASTY's Avatar
would it be recommended to get a programmer to adjust the fuel and what is a good one.
Old Oct 11, 2009 | 10:24 AM
i'm running Hondata s200 with p72 ecu .. that is my 'programmer'. Your tuner would take care of that part, all you need to do is get a Fuel Pressure Regulator and a Walbro 255lph fuel pump and install. Get a base map for your setup and drive to tuner. He will take care of the rest.
Do you know how much this will run you though ? .. Do you have a turbocharger / manifold, or not yet ? .. a decent setup will run you a few thousand + cost of labor if you're not installing yourself. Boost is no joke, be prepared.
mattsnooz
Engine Management and Tuning
May 15, 2008 11:21 AM
[LUDE]
Apr 29, 2004 11:41 PM
SKDRCR
Sep 7, 2003 05:50 PM
Sandor
Aug 5, 2003 12:26 PM
LudeSi-93
Jul 22, 2001 10:57 AM
