Starter gone?
Old Oct 10, 2009 | 12:12 PM
BLU CIVIC's Avatar
Track Advocate
Default Starter gone?
just got back from the track and backed my car up the drive way. it hesitated for a second then cut off and will not start. I've never had a starter go out, so i'm not too sure.
Old Oct 10, 2009 | 12:22 PM
blasterman87's Avatar
Default Re: Starter gone?
sounds like its cranking good enough, and making contact with the flywheel... you checked for spark/fuel?
Old Oct 10, 2009 | 12:26 PM
ryanevansoh's Avatar
thatw what my car sounded like when it was severly out of time. check timing
Old Oct 10, 2009 | 12:28 PM
BLU CIVIC's Avatar
Track Advocate
i haven't checked anything just yet. I raced it today. Turned it off and on with no problems. drove an hour home and right when i got home, it did this.
Old Oct 10, 2009 | 12:35 PM
was it starting easy before?
Old Oct 10, 2009 | 12:48 PM
BLU CIVIC's Avatar
Track Advocate
yeah, with no problems
Old Oct 10, 2009 | 12:54 PM
any ecu codes?
Old Oct 10, 2009 | 01:08 PM
BLU CIVIC's Avatar
Track Advocate
i'll let you guys know what happened, have a friend coming over to try and help
Old Oct 10, 2009 | 01:28 PM
BLU CIVIC's Avatar
Track Advocate
well turned the crank and a tooth was missing on the timing belt. friend said it was ok so i went back out to keep turning....well something's missing
Old Oct 10, 2009 | 01:31 PM
DCRB's Avatar
WTF??? time for a new timing belt. i hope nothing is broken
edit: was just going to say, a starter going out would be very slow cranking, occasionally you'd hear a clunk instead of the car cranking over
Old Oct 10, 2009 | 01:40 PM
damn, its a good bit off... mine was about that far off and i was ok. slap on a new belt and let us know
Old Oct 10, 2009 | 01:44 PM
BLU CIVIC's Avatar
Track Advocate
found teeth in my driveway, so hopefully nothing is messed up
Old Oct 10, 2009 | 08:03 PM
DCRB's Avatar
probably just wore out and what caused them to brake out was the torque of the car trying to start
shogun88
Feb 28, 2012 11:28 AM
SoHc94
Aug 8, 2006 04:55 PM
ZCHF
Aug 8, 2004 06:53 PM
eazye5591
Dec 12, 2003 10:22 AM
junya16
Mar 1, 2003 05:41 PM
