EJ1 not starting help!!!=[
Old Oct 10, 2009 | 11:34 AM
JdmSpecTeggy's Avatar
Default EJ1 not starting help!!!=[
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Pv9PjWwXu3g&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Pv9PjWwXu3g&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
i changed the started spark plugs and wires
also charged the batt.
someone help me idk what the problem is
it will crank then shut off again
=[ alternator? or maybe dizzy??
Old Oct 10, 2009 | 11:36 AM
93egSLEEPER's Avatar
Default Re: EJ1 not starting help!!!=[
are you getting fuel?
Old Oct 10, 2009 | 11:49 AM
im not sure i gas it all the way when starting it will start then shut of like in 1 sec.
and when it does start the idle drops hella low and shuts off.
but if i keep it revving at 2k for like 5mins it will idle normal
i dont know im tired of putting work in for this car.
Old Oct 10, 2009 | 11:51 AM
ounds like a sensor is bad. are all the sensors on the TB hooked up correctly?
Old Oct 10, 2009 | 12:04 PM
yep but now its not even cranking anymore
i think its my altenator, distributor, or my fuel pump, injectors.
idk this is my first ej1 i made a big mistake when trading my teg.
this motor is about to die out i think it has low compression
but it ran fine yesterday jus today it wont start =[
it just turn turns and starts then it dies out
i needa get to work too fucc man i think imma get fired.
Tyler Gardner
Classic Hondas
Oct 2, 2012 12:06 PM
joe_accord23
Aug 21, 2010 10:45 AM
MilFhunter001
Jun 1, 2010 06:55 AM
fozjared
Feb 22, 2006 03:29 PM
dubracr18t
Aug 25, 2003 08:08 AM
