where is my 02 accord ecu located
Old Oct 10, 2009 | 08:46 AM
hondafreak2134's Avatar
Default where is my 02 accord ecu located
I cant find where my ecu is can someone help me or knows where my ecu is located, i have a 02 accord coupe
Old Oct 10, 2009 | 09:08 AM
redbull-1's Avatar
Default Re: where is my 02 accord ecu located
It located in the center console below the radio.
See this TSB for an illustration.
http://www.tegger.com/hondafaq/tsb/accord/x97-058e.pdf
Old Oct 10, 2009 | 04:52 PM
well thank you i appreciate the help, now my other question is which wire would be the signal wire for the primary 02 sensor on a f23a4 engine, in the diagram it shows c16 on this site http://www.innovatemotorsports.com/r...nda_Accord.php, but i don't have a wire there and my engine is the ulev vtec, also this site gives me something different http://krcomp.com/pictures/ecu-pinout.pdf,
Old Oct 10, 2009 | 05:23 PM
redbull-1's Avatar
If your Accord is the ULEV, then it would have an air/fuel ratio sensor. I believe the signal (+) wire would be this one:
Old Oct 10, 2009 | 05:32 PM
how come it still shows that there is a c16 pin and on my ecu there is none? also i connected my air fuel ratio guage and nothin happens it just reads rich could this be because of a bad 02 sensor or no cat?
Old Oct 10, 2009 | 05:39 PM
redbull-1's Avatar
The reason the service manual shows a C16 pin is because the service manual covers different engines for those Accord years. C16 is for the F23A1 or F23A5 engine, which has a normal heated oxygen sensor. Your's doesn't have that pin because your's a F23A4, which has a air/fuel ratio sensor.
Old Oct 10, 2009 | 05:45 PM
ok so just leave it connected to the c14 pin out? and how come its just readying rich? could it be a bad 02 sensor or no cat?
iNfAmOuS_E46
Jan 21, 2013 07:19 PM
camp_kill_yourself
Jan 5, 2007 11:44 AM
