96 civic fuse box help!!!!!!!!
Old Oct 10, 2009 | 08:39 AM
crist488's Avatar
Default 96 civic fuse box help!!!!!!!!
im hooking up some gauges to my car and im trying to find a constant 12 v source and a switched 12 volt source in my fuse box inside the car but i dont have any tools to find out
Old Oct 10, 2009 | 09:13 AM
90Rexx's Avatar
Default Re: 96 civic fuse box help!!!!!!!!
constant 12v.... you can pull right from your battery... run a wire to your power cable from your batter.
and most everything in the fusebox is switched power... lights fuse radio fuse ect.
only thing i can think of thats constant power in the fusebox is... um.... actually cant think of anything lol
Old Oct 10, 2009 | 09:18 AM
crist488's Avatar
do you think slot 31 would be constant?? its says its ecm/pcm pgm-fi main relay integrated control unit fuse or can i use my radios constant power source?
Old Oct 10, 2009 | 09:20 AM
90Rexx's Avatar
use the radios constant power...
i think that fuse you speak of is switched ON using the main relay... meaning its not constant power.
can i ask why you need constant power for guages though???
Old Oct 10, 2009 | 09:22 AM
crist488's Avatar
they are the glowshift gauges so its need a constant source so that it can remember my color settings b/c it has 7 diff colors
Old Oct 10, 2009 | 09:25 AM
crist488's Avatar
u think i can splice the gauges ground wire to my radio ground wire
Old Oct 10, 2009 | 09:30 AM
90Rexx's Avatar
dont do that... just take the ground wire from your guages and make a new ground... get one of those connector end things and stick it where a bolt goes into something metal.
Old Oct 10, 2009 | 09:31 AM
apexi_rsx's Avatar
use a voltmeter in ur fuse box under the dash. there are a few open slots above the fuses that u can hook a female connector to. one is hooked to ignition power and would give u a constant 12 volt when the keys on and off when the keys off. hope that helps.
Old Oct 10, 2009 | 09:35 AM
90Rexx's Avatar
he said he doesnt have the equipment to check that stuff properly
Old Oct 10, 2009 | 09:45 AM
apexi_rsx's Avatar
u can buy one on ebay for less then 10 bux and use it a life time.
osbunjosh
50
Jan 29, 2024 05:20 PM
Outlaw-Hondaz
Oct 6, 2010 09:02 PM
_Cyclone_
Jul 17, 2005 08:06 AM
cd5_2NR
Audio / Security / Video
Jul 1, 2004 01:38 PM
02AccordCoupe
14
Mar 20, 2003 12:32 PM
