HELP! 2 radiators BLOWN in ONE day
Old Oct 10, 2009 | 05:35 AM
thierry's Avatar
Default HELP! 2 radiators BLOWN in ONE day
sooo yesterday i was driving along down the highway going about 55 when i heard a small pop and then steams started bellowing out of my engine bay like crazy... it was so bad that someone called 911 and said my car was on fire... soo like 15 volunteer firefighters and a firetruck full of fire fighters show up hahaha.. anyways i quickly found the problem when anitfreeze was alllll over my engine bay, and the seal on top of the radiator had blown out due to pressure... luckily i saved me original radiator so i got a ride home, came back, fixed it in like 10.3 secs... then i drove it home and when i got home it started smoking again... soo i look and the same exact thing happened to that radiator tooo!! im not really sure whats wrong with it.. does anyone have any idea? it seems ike its getting to much pressure and just blowing.. idk what would cause that? a blown headgasket? idk PLEASE HELP ME!!!!!!!!!
Old Oct 10, 2009 | 05:49 AM
90Rexx's Avatar
Default Re: HELP! 2 radiators BLOWN in ONE day
pictures of the "damaged radiators" please....
what radiator cap are you using?
Old Oct 10, 2009 | 05:52 AM
thierry's Avatar
im using a stock radiator cap... il get pics up soon
Old Oct 10, 2009 | 05:58 AM
silverbullet9626's Avatar
sounds like the thermostat sticking is causing your pressure prob.
Old Oct 10, 2009 | 06:01 AM
thierry's Avatar
thats what i was thinking... but would the thermo guage on the dash work if the thermostat was stuck?
Old Oct 10, 2009 | 06:07 AM
98greensi's Avatar
it more then likely your rad cap, it's designed to hold 14-16 psi in the cooling system, sometimes what happens is the springs get messed up in the cap and instead of releasing the extra pressure and fluid into the over flow tank it it just builds and builds until something pops. did you change the rad cap when changed rads?
Old Oct 10, 2009 | 06:08 AM
thierry's Avatar
mmmmm noooo... i did not change radiator caps... damn your right... i may have just been a half cup retarted..
Old Oct 10, 2009 | 06:39 AM
90Rexx's Avatar
sticking thermostat would nto cause excessive coolant pressure build up. so forget that idea
Old Oct 10, 2009 | 06:47 AM
thierry's Avatar
okay thank you siiir
Old Oct 10, 2009 | 08:50 AM
thierry's Avatar
any other input?
Old Oct 10, 2009 | 09:11 AM
90Rexx's Avatar
i say faulty radiator cap, or just bad luck that both radiators were on their way out.
oh another idea this is a long shot... but check your hood clearance make sure that for some strange reason your hood isnt hittong the radiator.....
... what a shot in the dark lol
Old Oct 11, 2009 | 07:43 PM
thierry's Avatar
from another thread.. ithink its forsure a headgasket or cracked sleeve.. luckily i got a new block with brand new pistons and bearings.. so that will be going in with a new radiator and thermostat just in case..
Old Oct 11, 2009 | 10:06 PM
98civdx's Avatar
Master Detailer
^^ your forgeting a rad cap....
Old Oct 12, 2009 | 04:51 AM
thierry's Avatar
i checked the radiator cap... it seems to work just fine..
Old Oct 12, 2009 | 07:38 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Is your overflow working? This happened to my buddy's car a long time ago and we could never figure out what was wrong. My guess was there was a clog somewhere in the coolant system.
But make sure nothing is clogging your overflow, like the hoses and crap like that
Old Oct 12, 2009 | 08:24 AM
thierry's Avatar
lol i know.. that was one of the first thing i checked..
Old Oct 12, 2009 | 09:48 AM
Jimster480's Avatar
well if you blew one radatior ofc you need to change the cap otherwise your gonna get owned like you did. maybe you should buy a new cap, that should fix the problem. otherwise you need a new thermo for sure. And its possible that the temp went up more but you didnt notice it.
Old Oct 12, 2009 | 11:18 AM
thierry's Avatar
i watched the temp the whole way home.. it was at its normal tempertaure... me and my dad boil tested the thermostat and it opened all the way upp at about 180 degrees like it should..
Old Oct 12, 2009 | 11:29 AM
gwl's Avatar
gwl
With the prices of the cap and thermostat are cheap enough to replace as a preventive maintenance. Last week, I replaced my radiator because the top seam was leaking. I put on new hoses and a radiator cap since it wasn't any extra work to so.
Old Oct 12, 2009 | 11:58 AM
Jimster480's Avatar
just get a new cap then...
Old Oct 12, 2009 | 12:05 PM
civic_r87111's Avatar
If it was a cracked sleeve or a really bad blow in the HG u can take off the rad cap and start the car and it will blow the coolant out the rad. I mean it will shoot it out too but in ur situation just get a new car and keep and eye on the temp.
Old Oct 12, 2009 | 12:15 PM
Jimster480's Avatar
he blows a RADIATOR and he needs to get a NEW CAR?!?!?!?!?!????!?!?
Old Oct 12, 2009 | 12:27 PM
thierry's Avatar
hahahahahaha a new car?!?!?!?! i, fortunatley, have been building a new block.. which is almmost done.. so im just putting that in with a new radiator and stuff.. hahaha
Old Oct 12, 2009 | 12:35 PM
LMAO...... WOW I didn't even catch that, I meant to say Cap lol.
Old Oct 12, 2009 | 12:42 PM
thierry's Avatar
hahahaha
