D15b7 valve cover problem.
Old Oct 9, 2009 | 08:43 PM
joshsayswhatt's Avatar
Default D15b7 valve cover problem.
Ok so I've been meaning to change my valve cover gasket for a while and finally got around to it today. But when loosening one of the nuts off the top with about 3 pounds of pressure the bolt just snapped. And now I'm left with a valve cover that won't completely tighten and a hole where the bolt should be. Is there a way to get that stud out and replace it. And if so how and where can I find one? What is it even called? Thanks.
Old Oct 9, 2009 | 10:01 PM
DCRB's Avatar
Default Re: D15b7 valve cover problem.
just go to your local junk yard. any non vtec d series from any 88-95 will have the stud you are talking about. i broke one of those one time at like three in the morning. SUCKED *****
Old Oct 9, 2009 | 10:04 PM
roycivic92's Avatar
sears has a kit to take out broken bolts works good
Old Oct 9, 2009 | 10:37 PM
thumper64's Avatar
Just weld the cover on...
Old Oct 10, 2009 | 03:57 AM
sde780's Avatar
take the valve cover off, you need a 12mm i believe wrench to get it off. its one of the long bolts that holds the rocker arms down
Old Oct 10, 2009 | 05:41 AM
Any thing else like will they hve this at an auto part store.
Old Oct 10, 2009 | 05:43 AM
I know the bolt will come out. But what is that bolt called.
Old Oct 10, 2009 | 09:43 AM
apexi_rsx's Avatar
u need to go to a junkyard and get the bolt or online @ majestichonda.com
Old Oct 10, 2009 | 12:51 PM
Ok but what is the part number or part called. There isn't many upick yards around here.
Old Oct 10, 2009 | 06:13 PM
Come on someone help me out.
Old Dec 16, 2009 | 01:24 PM
sickopsycho's Avatar
New User
It's called a valve cover bolt.
Most likely you aren't gonna find it at an auto parts store- you may, however, find one that will work at a fatener supply place if there is one local to you. There is a place in Raleigh called Wylders- they specialize in nuts and bolts. Somewhere similar to that could help you. Just take off another one and bring it in to them and have them match it up. It shouldn't cost you more than say $5. I hope you have solved this problem by now but if not- there you go.
Old Dec 16, 2009 | 01:32 PM
itsnotfast's Avatar
No, its a 10mm
That works too lol.
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
genetsang
Mar 25, 2004 02:40 PM
genetsang
Mar 25, 2004 02:34 PM
bartek_b
Apr 15, 2003 11:21 AM
illusion
Feb 27, 2002 03:17 PM
