D16Y7 Block to D16Z6 Head
Old Oct 9, 2009 | 09:59 AM
GiMpInThaCiv's Avatar
Default D16Y7 Block to D16Z6 Head
So ive been searching google and a few honda sites the past few days
I picked up this site http://www.knology.net/~jediklc/D.htm
Im interested in compression
Currently the block is assembled with eagle rods / viata pistons, stock bore
the head is also stock with just a zex cam
I put all the info into the calculator and got to 8-1 compression
Will that be an issue?
If i use a D16Y8 head gasket 2 layer it will bump it up to just over 9 to 1.
Is the D15y8 headgaset a normal 2 layer HG? Ive also seen it stated as a 3 layer just like the z6 head gasket on the internet.
Just looking on input about compression and which head gasket to use.
Old Oct 9, 2009 | 10:20 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: D16Y7 Block to D16Z6 Head
8.1 ...do you know what size vitara said those pistons were?
8.1 wil suk and a lower comp will throw off the ecu if its a stock ecu
thinner headgasket wont bump compression like you thnk
Old Oct 9, 2009 | 11:37 AM
75.5
Old Oct 13, 2009 | 04:57 PM
dizzy_drifter's Avatar
i might be new but somethin isnt adding up, are you pistons dished?
Old Oct 16, 2009 | 08:54 AM
Manny 77's Avatar
See what happen is that the vitara pistons we used them if you r planning to install a turbo charger cuz the comp is 9 to 1 is very low but if you r not planning to get a turbo and you want some nice pistons get hi comp pistons or go back to the factory one's...
Old Oct 16, 2009 | 09:24 AM
Jimster480's Avatar
well if he put vitara pistons in there, then im sure hes going turbo. Just get a D16Y8 FEL-PRO head gasket. it will be fine.
http://www.zealautowerks.com/dseries.html
use that. you dont have 8.0CR. its more like 7.56. I have the same setup but STD bore Vitara's. I have 7.49CR. it runs fine and its great under boost. I run a D16Y8 FEL-PRO head gasket with ARP Studs.
Also i just noticed, in the first post you say stock bore. Then in the next post you say 75.5. Stock bore is 75mm.
monster_c
Apr 5, 2012 09:53 AM
1SIKZ06
Mar 4, 2009 12:59 PM
sauceja
May 17, 2006 07:43 PM
iceman95
Mar 2, 2006 09:24 PM
