wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have
Old Aug 28, 2002 | 11:52 PM
itrboi's Avatar
Default wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have
wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have plus dc 4-1 header, greddy exhaust sp, short ram aem intake, aem fuel rail?
Old Aug 29, 2002 | 12:55 AM
b18c5 turbo's Avatar
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (itrboi)
i would prolly base my guess out of a quick calculation..i didnt really sit down to think about this add-on ull get wid all those..so if im kinda or very off..dont blame me..cuz im jus throwing a estimate...stock hp on a type R is 195..and most the JR SC will add is 100..im guessing..so lets sey 295..wid the fuel rail, intake, headers,umm..ur lookn about 310..or 320..thats what i would most approx. sed..but then again..i could be wrong..
Old Aug 29, 2002 | 01:14 AM
PyR01-0347's Avatar
It all comes down to how well you tune your car. Just slapping on the SC will not give you 100hp. Just ask Rboosted.
Old Aug 29, 2002 | 01:23 AM
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (PyR01-0347)
good u braught it up..dats actually true..its all down to the tuning the motor..theres many ways u can set it so u can get more out of it..dat actually didnt run through my head.. ;/
Old Aug 29, 2002 | 01:42 AM
MR. ARIZONA's Avatar
5 Ponies YO!
Old Aug 29, 2002 | 04:16 AM
TypeR0936's Avatar
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (QUICKTEG)
You are probably looking at somewhere near 200 whp at the wheels
Old Aug 29, 2002 | 04:23 AM
Brian*'s Avatar
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (TypeR0936)
i've seen as low as 170's, but its aaaaaall in the tuning of it. the stock ecu on that particular car liked to run super rich from about 6500rpms and up, and you could see the dyno plot plateau when it got to 6500. made good power till then though
Brian
Old Aug 29, 2002 | 05:05 AM
Batoutahell's Avatar
With your mods, I predict 180whp. You MUST tune the a/f to make more power, and you'll need a v-afc, hondata, or something similar to accomplish this.
Old Aug 29, 2002 | 06:02 AM
Mr Hammond's Avatar
a/k/a Jomo
With those mods and the stock JRSC kit @ 5.5psi and TUNING! Atleast get a V-AFC or if you can Hondata 2B. You will see around 230whp.
Old Aug 29, 2002 | 06:12 AM
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (Mr Milano)
Wtih his mods and mucho a/f tuning with a wideband dyno, he can expect 200-205whp. He might get lucky and hit 210whp if he opens up the collector and the cat. To go higher, you really need to adjust your timing also. The v-afc won't let you (re-)advance your timing, whereas a standalone or some piggyback computers will.
Old Aug 29, 2002 | 08:00 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Depending on your tuning and supporting mods, anywhere from less than stock to 240+ on 8psi.
Old Aug 29, 2002 | 08:13 AM
Majuniors_no_vtecfu's Avatar
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (newt2)
its all in the tunning you can put a s/c on it and still get smoked by all motor cars if you dont tune it right.....so really cant perdict your out come of power
Old Aug 29, 2002 | 08:18 AM
Bbasso's Avatar
if you go to their website you can get info like this.
[Modified by Bbasso, 12:18 PM 8/29/2002]
Old Aug 29, 2002 | 08:23 AM
mikeSONICGSR's Avatar
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (Bbasso)
Look at the GSR dyno?
An ITR only has 1 more HP than a GSR?
[Modified by mikeSONICGSR, 12:25 PM 8/29/2002]
Old Aug 29, 2002 | 08:31 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (mikeSONICGSR)
With a half pound less boost and no cam adjustments sure.
Old Aug 29, 2002 | 09:21 AM
ITR41's Avatar
New User
I am goin with JRSC in spring and I am thinking of using the 5.5psi pulley for at least a while with prelude injectors(290cc), the JR fuel pump, a BTC, and hopfully water injection(probably won't be till next summer)....I will have JDM DC header test pipe, tanabe RM, clutch, flywheel, and vafc.....
here are my questions:
1. will my exhaust flow enough to make over 200whp?
2. will the vafc let me lean it out enough after 6500 to see a real gain?
3. if I run a FMU will I still beable to tune it with the vafc?
I'm looking for about 220whp if I can get there with the 5.5psi pulley... I will be goin with 8psi sometime next year(end of summer proabably). what fuel mods will I need to keep it RELIABLE......Rboosted- any suggestions?
Old Aug 29, 2002 | 09:48 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (ITR41)
Everything sounds good, but forget the VAFC and BTC. Get a Hondata or an AEM EMS instead (If you have a tuner in your area, Hondata is probably the best choice. I have an AEM because there's nobody who can tune Hondatas in Colorado). In the long run you'll save money and run better. If you decide not to do a standalone, I'd get a J&S over the BTC anyway. It'll retard the timing on demand (read: high knock count) instead of all the time. You can use both if you want, but by that time you could've already bought a Hondata.
IMO, 290cc injectors are too small. You'll need to up the fuel pressure to get the fuel you need, which means you'll need to keep the Jackson FMU (sucks) or buy a Cartech (more $$$$$).
I'm using 450cc DSM injectors right now. You can get them for about the same cost as Prelude injectors (I got mine free) and you can pull a resistor box out of older Hondas in the Junkyard for about $30. I think any injector at or over 360cc can flow enough to support the boost without bumping pressure.
All IMO of course. Others may have different ideas.
Old Aug 29, 2002 | 10:26 AM
Hooch'n's Avatar
If the GSR only had one less hp the ITR.........what does that tell you!!!!!!!
ITR=N/A
Old Aug 29, 2002 | 10:35 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: wuts a ruff estimate of hp an ITR w/ jacksonracing s/c will have (8400-RPM)
lol, pretty much
Old Aug 29, 2002 | 10:48 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
NA = race gas special for twice as much dough.
Old Aug 29, 2002 | 10:54 AM
StockBlkEK's Avatar
he is a 98 sc type r http://godspeed.hack.net/Projectcar2.html
with tuning you can make good power
look at the torque
Old Aug 29, 2002 | 11:17 AM
Rboosted717's Avatar
I say 190whp with your setup. I will guarentee on a dynojet that it wont hit over 200whp. Also the AEM fuel rail will do nothing for you. I have pushed over 260whp and the stock rail is just fine as long as you upgrade the injectors and tune it.
Your setup plus a tuned ECU setup, will probally yield no more then 210-215whp.
Old Aug 29, 2002 | 11:25 AM
1. yeah it will flow good. A kamakaze will do better then the JDM DC header though. Also what rear exhaust are you gonna use. I would suggest a good 2.5-3" exhaust.
2. Yeah the VAFC will help alot. If you raise the boost, you will probally need a FPR or larger injectors to help with some more fuel down low and mid range.
3. Yeah you can tune a FMU (FPR) with the VAFC. Try getting the vortech/B&M command flo, etc... FMU (FPR). Those units are easy to adjust and are very clean looking.
220whp on 5.5psi is do able. As long as its tuned good with a all around good setup, you can hit it.
For 8psi I would suggest larger injectors OR getting a larger fuel pump to raise fuel pressure a lot and keep it running good. I would suggest the larger injector route because thats the proper way to add fuel. 310's will work ok for 8psi. Also a Hondata setup or similar might help with tuning down low and getting rid of tip-in detionation if any is present. With a tuned 8psi you can hit around 220-240whp on a tuned setup. You can hit slightly more if you really tune the car and have a very free flowing exhaust setup.
Old Aug 29, 2002 | 11:27 AM
ITR41's Avatar
New User
sorry it was so jummbled....you just misunderstood me...on 5.5psi I will be using the 290's but when I go to 8psi I will probably go with DSM injectors.....as for the hondata. A few of my friends have it and seem to like it a lot. so in the long run I will probably have one....but will the vafc tune the car enough to get it on the road and making some power? I don't expect to make what R boosted makes with just the set up I have but I would like a little over 200whp on 5.5 psi
Youngcity
Honda Civic (2001 - 2005)
Jun 12, 2007 03:15 PM
99B16Si
Feb 7, 2007 05:06 PM
mbdelsol
Jan 4, 2006 09:57 PM
kriptik
May 19, 2004 05:44 PM
Armaan
Sep 3, 2003 01:16 PM
