Starting air valve and IABS JDM h22a
Old Oct 9, 2009 | 04:24 AM
mattsnooz's Avatar
Icon6 Starting air valve and IABS JDM h22a
Would it be benificial to swap over these two devices to my Jdm h22a? I have a tunable ecu running on it so I can activate IABs without an issue. If I do add in IABS what engagement point roughly should I use?
Vtec is set at 4688 as thats where it seemed to improve the overall powerband. I might go a bit lower to increase the overall power (smooth power band to more linear) rather than peak, which leads me to my next question though which is at what rpm I should be engaging my h22a vtec with stock everything except I/H/E?
I know I need a dyno tune to get the best answers, but as I'm trying to self tune I would like to know rough guidelines of whats approximately good for the average bolt-on jdm h22a.
Old Oct 9, 2009 | 04:49 AM
PirateMcFred's Avatar
Default Re: Starting air valve and IABS JDM h22a
Put it on a dyno. Tune the IABs yourself just like VTEC. Start with a low activation point, then a high activation point and see where the lines intersect. That's what I do. Seems like 4500 worked pretty well for me but I had Type-S cams on a 2.2 liter.
Old Oct 9, 2009 | 11:17 AM
flyrod's Avatar
The starting air valve is pointless. Leave it off. IAB's will give you a bit more torque on the low end. Worth hooking up a wire IMO.
Old Jan 25, 2010 | 06:18 PM
mattsnooz's Avatar
I noticed in my options in crome that I cant edit when my IABS engage. Its set over 7900 rpms. I want to set it to a different number but the map was generated off a set that didn't have IAB option. Is there anyway to edit the IAB?
Sir001
Engine Management and Tuning
Jan 14, 2017 08:52 PM
thatsmyhonda
Dec 11, 2009 04:59 PM
oneesk1e
Sep 13, 2004 07:59 AM
spark90703
Jun 29, 2004 09:13 PM
