Need a builder...paypal ready
Old Oct 8, 2009 | 09:34 PM
icucnme's Avatar
Default Need a builder...paypal ready
I need someone to weld me up about a 1qt aluminum box that will be used as a catch can.
9" wide---4" tall---3" deep. 1.5" tube welded on the top for my breather filter. I will send you the barb fittings in the mail and have you weld them on. Needs 2 mounting tabs. I have all the measurements and a cardboard mock up.
Give me a price shipped. Thanks,Adam
Old Oct 8, 2009 | 09:49 PM
siblues's Avatar
Default Re: Need a builder...paypal ready
I would be a little more specific like where and if you want any breathers on the tank and does it need any mounting tabs or maybe even what car its going into.Good luck
Old Oct 8, 2009 | 09:59 PM
icucnme's Avatar
I just want a sealed box in those dimensions. I've measured where I'm mounting it and that will fit. I'll drill 2 holes and install the barb fittings on the side for the hoses and I'll drill 1 hole on the top to install a barb fitting for the breather filter. I'll drill a hole in the bottom and just put a bolt in it for a drain plug.
Going to check with a custom cycle shop in my town tomorrow and see what they would charge me.
Old Oct 8, 2009 | 10:15 PM
GT35R_EF's Avatar
Make mine whatever you want
PM me.
Old Oct 9, 2009 | 10:29 AM
icucnme's Avatar
9" Wide 4" High 3" Deep. 1.5" tube welded on top for my breather filter 'near center'
1.25" Wide tab 2.5" Long welded on the right of can 2.5" Up from bottom 'back edge'
1.25 Wide" tab 2.5" Long with a 1" foot. 'so 3.5" total' welded on the left of can 1" Up from bottom 'back edge'
5/8" barb fittings welded 1" from top/bottom edge
2" in from the front edge
Old Oct 9, 2009 | 11:16 AM
champLSinteg's Avatar
you cannot weld those barb fittings on. You need aluminum fittings. PM me I can help out.
Old Oct 9, 2009 | 12:24 PM
icucnme's Avatar
Those are air chuck fittings that I used for mock up purposes only.
I have aluminum 1/2" npt -- 5/8 barb fittings on the way.
Project is on hold anyways. I have to put my air filter were I was going to mount this at.
.RTErnie
Jan 10, 2006 05:38 PM
riceball777
Jan 4, 2006 12:24 PM
transpar_nt
Jul 3, 2005 05:36 AM
1.8EG-T
Feb 25, 2005 09:23 AM
accordfreak93
Mar 11, 2003 06:54 PM
