gas mileage tips.
Old Oct 8, 2009 | 07:46 PM
toshko321's Avatar
Default gas mileage tips.
hey, guys, i need some tips here. i get around 17-18 mpg on my 99 civic dx. i just bought spark plugs and a distributor cap and it should come in soon. after those come in i will see if my mpg goes up at all. other than that do you have any suggestions on what else i can replace to get some extra miles (except drive like an 90 yr. old)
Old Oct 8, 2009 | 07:50 PM
mortificationrock's Avatar
Default Re: gas mileage tips.
Do a full tune up. Change your air fliter , oil, spark wires, plugs,rotor, and especially that damm PCV valve. That little thing kills alot of miles. Also can be your o2. But u really got crappy *** mileage. I get 35mpg on my 95 civic with vtec and bolt on's. even with my old rusty oem fuel filter. Oh yeah cange the fuel filter also.
Thats the best advice i can give.
Old Oct 8, 2009 | 07:53 PM
ej1love's Avatar
^ good advice, plus driving habits are the biggest factor...
Old Oct 8, 2009 | 07:58 PM
x2...when i drive like grandma i get 31-35mpg. When i be hitting mad vtec i get 30mpg.
Old Oct 8, 2009 | 08:01 PM
Former User's Avatar
Also set the ignition timing to spec. Any CEL codes?
Old Oct 8, 2009 | 08:06 PM
I knew i was forgetting something.
Old Oct 8, 2009 | 08:09 PM
pumafeet10's Avatar
do as most have said with a full tune up
make sure you have the tire pressure up, if you really want better mileage up the psi to max sidewall, go to 0w30 syn oil, drive briskly to your target speed and keep that speed LOW that will kill mpg ridiculously!
Old Oct 8, 2009 | 08:51 PM
toshko321's Avatar
i already have a cold air intake, new oil filter, new oil, new spark plugs coming in, and i need a pcv valve and i should be set. so with the pcv valve and the spark plugs and rotor i should be getting better mileage right?
Old Oct 8, 2009 | 09:01 PM
My guess would be yes...but take in mind if you have a faulty o2 sensor..that wont help. Do u have any CEL's?
Old Oct 8, 2009 | 09:03 PM
S2Integra's Avatar
O2 is usually a mjaor cause, take it to the dealer and have theme clean the IM runners ans header. This does work as I experience it first hand.
Old Oct 8, 2009 | 09:11 PM
toshko321's Avatar
alright thanks guys, and no i dont have an CEL.
Old Oct 8, 2009 | 09:21 PM
94_DC's Avatar
Will help alot, I also had the same problem.
Old Oct 8, 2009 | 09:56 PM
boxeocampeon's Avatar
yup replaced my o2 sensor and get way better gas mileage
Old Oct 9, 2009 | 02:51 PM
toshko321's Avatar
yeah i bought the pcv valve, hopefully that would fix it, right?
Old Oct 9, 2009 | 02:56 PM
98civdx's Avatar
Master Detailer
driving habits are going to be the biggest factors, and judging by the other threads i have saw from you, you drive your car very hard, drive it like a grandma, and i promis your mpg will increase.
Old Oct 9, 2009 | 03:03 PM
toshko321's Avatar
haha ok idk how u got to the conclusion that i force the **** out my car...? obviously i will push my car a bit sometimes, because its a honda, and its fun to drive... im sure you do too but you might get much better gas mileage than 17mpg...
Old Oct 9, 2009 | 04:33 PM
98civdx's Avatar
Master Detailer
^^ how i got the conclusion, is becuase you have said it in past threads dont you read??
im judging you at all, i really dont care what you do with your car,
yes from time to time i will push my car a little hard and yes i get any where from 25-30 miles around town.
also how i got to my conclusion is YOUR GETTING 17MPG!!!!!!!!!!! inless your car is a complete peice of ****, and runs super freaking rich you should be getting way better then that, therefor you most be driving the car hard!
Old Oct 9, 2009 | 05:16 PM
toshko321's Avatar
hey buddy chill the *** out, im asking you guys what to replace in order to improve my gas mileage, i realize that i have to drive it less harsh but you are not helping much in these posts...
Old Oct 9, 2009 | 05:20 PM
shawn_crx's Avatar
pms
Old Oct 9, 2009 | 05:35 PM
98civdx's Avatar
Master Detailer
your an idoit.
thats what you always say, no one helps me!
i siad you drive your car very hard, this is a main reason why your getting shitty mpg,
you push your car cause its a honda lol and a bit? that is not going to give you 17mpg...
Old Oct 9, 2009 | 05:46 PM
toshko321's Avatar
k 98civdx thank you for all your tremendous help, without you i dont know what i would do man, you gave me all these helpful tips... thanks a lot
preludepower
Oct 6, 2009 08:24 PM
EvenStar
Oct 2, 2007 11:44 PM
joaodossantos
Jun 9, 2007 08:18 PM
jdadams12
Feb 22, 2007 09:24 AM
743power
Dec 11, 2005 07:28 PM
