Hood Pin Question
SO, i just picked up a VIS oem style carbon hood for the low low price of a case of miller lite and a dozen wings (literally). However, the problem is it had hood pins in it, and i am no fan of hood pins.
I was looking at the aerocatch hoodpins due to their rather flush mount design. I googled the dimensions and came up with 126mm (4.9") in total length and 69mm (2.7") in width.
I measured the pre-existing hood pins and they are circular and about 2.3" in diameter.
Now, it seems like the aerocatch hood pins will replace the old poopy hood pins barely when it comes to width, the only thing that concerns me is the slight tear-drop design may not cover the width compeltely as it begins to get narrower.
What i am looking for specifically is anyone with experience with the aerocatch fasteners to give me their thoughts on if they would be able to replace the old hood pins. It's hard to say from the picture and if i could get a definite yes or even a definite no, it would save me some time, aggravation and about $100.
Also if anyone has any other suggestions on hood pins similar to the aerocatch i am open for suggestions, i just haven't found any other options yet.
thanks fellers
thanks fellers
ah i also just realized they come with templates, so if anyone has one they can scan and post or knows where i can find one that i can print out and just see for myself that'd be awesome as well.
if i were planning on using filler and color matching, i would just put my stock hood back on. unless you are some type of paint wizard and can mix up some carbon fiber colored paint, thanks anyway.
anyone else?
anyone else?
Something like this maybe? I would just get some type of black hood pins, or make something to put under the type you are looking at.
I was not aware of the style of pins you posted, those look like they will blend in best, and assuming the locks are better, provide some extra security as well.
Edit: here is a carbon fiber set of the pins posted above, made by NRG. http://www.robearracing.com/pd-nrg-r...-universal.cfm
A quick google search answers all
http://www.aerocatch.com/automotive-operating.html
You'll need to cut into the underlying hood support (webbing) to accomodate the aerocatch's depth. I don't think you'll be able to install them until you fill the existing holes in part or entirety.
