c23 acrua legend type ii swap?
Old Oct 8, 2009 | 07:30 PM
dklein's Avatar
Default c23 acrua legend type ii swap?
has anyone heard of someone putting a c32 acura legend type ii engine in a civic hb?
they are pretty cheap on jdm imports and have 230hp...? was curious if it would fit...seems like a bargain...
http://www.jdmenginedepot.com/jdm_en...Type_II_Legend
Old Oct 8, 2009 | 08:05 PM
axegrinder87's Avatar
Default Re: c23 acrua legend type ii swap?
i doubt it. thing about those is that they sit in the bay like a rwd, so the tranny bolts to the back of the motor, and i dont think itll have anywhere to go in a civic. check out this pic of a type II legend to see what im sayin.............
http://www.sqlgnd.com/IMG_0981.jpg
Old Oct 8, 2009 | 09:07 PM
dklein's Avatar
yeah - i do see what you mean...i wonder if you could mount the engine sideways...probably not worth the trouble...was just look'n for a cheaper swap...but that is too much work...if i convert to rwd then i might as well just make a civette....lol ;-)
thanks.
Old Oct 8, 2009 | 09:11 PM
98civdx's Avatar
Master Detailer
look into a j series swap. v6 but you can keep it front wheel drive.
Old Oct 8, 2009 | 09:16 PM
dklein's Avatar
is there good aftermarket performance support for the j-series?
Old Oct 8, 2009 | 09:57 PM
20-EM2-05's Avatar
Hasport has made mounts for the J-Series and if you need help with the J swap, just use the search or google it. I'd post a link here, but we aren't allowed to do that. So if you need the link just ask for a PM.
Old Oct 8, 2009 | 10:08 PM
98civdx's Avatar
Master Detailer
sence when can we not post links? i have posted many links in the past....
there is suprising a lot of good info on the j series swap, but its not your average everyday b series swap, and as i understand require ALOT of work to make this work,
and your going to have to figure something to do with you hood, as it wont clear.
Old Oct 9, 2009 | 07:25 AM
dklein's Avatar
this is good info...thanks!
Old Oct 9, 2009 | 08:31 AM
a j swap is about the same as a k swap. gotta relocate the tranny mount. but you gotta either keep your hood off or cut an enormous hole in the middle to clear the intake.
there really is no aftermarket other than intake and header.
but since hasport is making mounts now, more people will do the swap, and the more people that do, the bigger the demand for aftermarket parts will become, hence a greater aftermarket.
and just in case you might be confused, the type II is fwd
Old Oct 9, 2009 | 08:35 AM
roycivic92's Avatar
yeah i was thinking about a j swap but on a eg the hood wont clear
Old Oct 9, 2009 | 05:14 PM
splatV6's Avatar
Go to J32a.com, they have a ton of info there.
Old Oct 9, 2009 | 08:16 PM
20-EM2-05's Avatar
Iono, but sometime when people ask for K series help/J series. Whenever I direct them to J32A.org / K20a.org. My post always get deletes and the MOD sends me a message about it being deleted. Iono, maybe it's just me haha.
Old Oct 9, 2009 | 10:12 PM
98civdx's Avatar
Master Detailer
weird, i have never had a post deleted because of a link lol
maybe it just is you, but it also depends on the mod.
Old Oct 10, 2009 | 12:16 AM
durfeec's Avatar
a k/j swap wont be a cheap easy swap anyways. if you want cheap/easy/power turbo a d.
Old Oct 10, 2009 | 05:43 PM
splatV6's Avatar
Not really, my j swap cost about 4G
Old Oct 10, 2009 | 07:16 PM
durfeec's Avatar
and you can have close to the same power for about 1.5G outta a turbo d. and you can put your hood on.
YvesTeggyLs
Jan 20, 2009 03:13 AM
02NJHondaep3
Feb 22, 2004 10:52 AM
NYCSACH
Nov 28, 2002 09:56 AM
iNtoXicaTedSPOON
Nov 21, 2002 08:55 PM
